Old 07-01-2008   #1
Aurora40
Aurora40's Avatar
Default Towing a ZR-1, how much towing capacity?
We are looking to get just a plain old truck. My wife mainly wants to be able to haul stuff around like mulch, furniture, etc. I figure if we are going to get one, why not one that is capable of hauling the 'vette if need be. But I want as little truck as possible (to save on up front cost as well as on gas).
How much towing capacity would be needed to tow the car and an open trailer? Would 5,000 lbs cut it? I know very little about towing or about trucks.
Old 07-01-2008   #2
Jeffvette
Default Re: Towing a ZR-1, how much towing capacity?
Bob, I've got a 2002 2wd Chevy Silverado 1500 with the 4.8 V8. It tows just fine with the race car or the ZR-1 behind it on a flat bed trailer. If you are wanting enclosed you will have to step it up to a 2500 series.
The truck gets good gas mileage as well. I'll get 400-450 miles per tank on the highway, and the tank is 25 gallons.
Old 07-01-2008   #3
Aurora40
Aurora40's Avatar
One truck we're going to look at is an '07 F-150 with the 4.2L V6. The trailer rating is like 5,100, which I think is the same as the 4.3 and 4.8L Silverado. Though that may be more a factor of the hitch than anything else. Certainly the 4.8L packs way more hp and a bit more torque.
I'd like to get something newish with lowish miles (under 50k would be nice) for under $10 grand. V8's seem to run a little more than this in general, at least what I've seen so far. We are in no hurry though, so maybe I should watch the market a bit more to get a better feel for it.
Thanks Jeff!
Old 07-01-2008   #4
Jeffvette
Bob, if you stay within the GM family and get a LS motor, you are also just a tune away from some better gas mileage. Also a cam swap will help with some power, and the gas mileage will also have a slight increase.
GL in your search.
Old 07-01-2008   #5
Jagdpanzer
Jagdpanzer's Avatar
You should have no problem trailering your Z with any 1/2 ton pickup truck equipped with a proper trailer hitch. Engine size is dependent on how much you like to pass slower traffic. I have a Ford Expedition and it works fine to.
Old 07-01-2008   #6
tccrab
tccrab's Avatar
If you are in no rush there will be a huge glut of high end pickups and SUV's on the market by the end of summer.
With gas/diesel prices being what they are, people will be unloading them by the truckload (pun intended).
My brother up in Seattle just recently picked up a 2002 Silverado 2500 4WD with ~85k miles on it for <$6k.
TomC
Old 07-01-2008   #7
cuisinartvette
Youll like the Silverados, Aurora. 02 was the last yr for the rounded front end.
Have an 02 with the 5.3, love it. Mileage is liveable, very comfortable, plenty of power, cant kill that LS motor. Hit passing gear and it barks the tires. You can get em cheap, people are giving them away right now.
Old 07-01-2008   #8
Nick
I tow a 5,000 lb. boat with my 02 Silverado, don't even know its back there. 4:10 gears definitely make a difference; glad I got those. Fuel economy? What's that?
Old 07-03-2008   #9
bldavis11
Check the "maybe" box on the enclosed trailer deal. My old man just towed an enclosed trailed filled with furniture from Arkansas to Florida in a Nissan Titan (5.7L V8) without a problem.
bldavis11 is offline   Reply With Quote
Old 07-03-2008   #10
USAFPILOT
USAFPILOT's Avatar
My NIssan Titan didn't even know the vette was back there. Any stock Titan can tow 9500 pounds, maybe more now but mine was a first year truck in 2004. Its more truck than you'll need but you just cant beat the interior and ability of the truck dollar for dollar, and the have a DOHC 32 Valve V8 like the ZR-1. Cool Huh. Pick one up for aroun 10G's probably unless you want one that is loaded. Fuel Economy is an issue at 16 MPG.
