06-26-2008 | #11 |
Re: Flywheel Balancing 1992 ZR1
Yes, harmonic balancer pins are no longer available. I'll be weighing the ones I got coming in and will get sizing done. This will be a interesting write up for the registry newsletter dealing with the harmonic balancer.
06-28-2008 | #12 |
check the balance on the flywheel and clutch assembly
the "tuning pins" for the balancer and flywheel for the dynamic balance should be transferred fromt the old flywheel to the same positions on the new one. but since that can't be done, the only way to do it again is having the rotating assembly balanced which really isn't feasible (or cheap) because you need the crank out of the engine. the "goo" on the beam is an isolater under the c beam bolts I believe it's purpose is to better secure the bolts and keep them from "digging in" to the soft alum the bill boudreau beam plates do a much better job at that and stiffen the drive train. on the balance problem, since the engine "should be" internally balanced I don't think you should be noticing a big difference with a new flywheel as the tuning pins really just are "fine tuning" the balance to achieve the legendary smoothness. hopefully it's something else like the driveshaft!
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
06-28-2008 | #13 | |
Do you still get the vibration when sitting in neutral and revving the motor up? |
06-28-2008 | #14 | |
10-04-2010 | #15 |
I have a vibration that comes on strong above 5K and really strong by 7K in neutral and while in gear. It is not the drive shaft. My car has 50K on it and has not had a new clutch, and has not been opened up to the best of my knowledge. Could my harmonic balance or flywheel just get out of whack on its own?
10-06-2010 | #16 |
There is a technique to doing the half shafts. You have to take one of the caps completely off to get them into place. But there's a little more to it than that. I'm getting ready to do my half shafts in the coming week. Maybe I'll do a "TAH DAH" how to for it.
