06-24-2008 | #61 | |
Re: Fuel Injectors
TomC
06-24-2008 | #62 | |
Re: Fuel Injectors
http://www.pnwzr1.net/LT5_tear_down2.htm |
06-24-2008 | #63 | |
Re: Fuel Injectors
I smell a powder coating job coming!
06-24-2008 | #64 |
Re: Fuel Injectors
If you order the Accels from JeffVette and ask him *VERY* nicely, I'm sure he'll remove the tabs for the primaries.
Won'tcha Jeffie??? Specially since it sounds like he's sending his top end to you for a powercoating... TomC
06-24-2008 | #65 | |
Re: Fuel Injectors
07-25-2008 | #66 |
Re: Fuel Injectors
First I wanted to say thanks to everyone who contributes their vast knowledge to this board.
I just replaced the injectors in my 1990 with the Accels from Atlantic Speed Performance Parts (and got my free shirt with each set.) Also from the recommendations I got scouring the boards I changed out my plug wires and fuel filter and reset the ECM. I am amazed at how much of a difference it made! My Z only has 35,000 on it so I felt like it was still pretty fresh - but now it jumps like new again! Also, I spoke to Jeff at PNWZR trying to buy the injectors and Marc Haibeck trying to buy the illusive O rings for the primary injectors, and they both confirmed that there is no need - you just use the stock GMs that are in there already. Also both of those guys were very friendly and helpful. Thanks! |
08-10-2008 | #67 |
Re: Fuel Injectors
Hi ,
Thanks for your post. I am installing new injectors I got from Kurt White. Was not sure about which groove at the top of the injectors to use and then I remembered your post.
91 Turquoise Metallic Haibeck 525 #0134 |
08-31-2008 | #68 |
Re: Fuel Injectors
I have an opportunity to buy some injectors from a '93 ZR-1. I have a '91 that needs some injectors and am curious if the '93's will fit. Any comments on this?
Thanks
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
08-31-2008 | #69 |
Re: Fuel Injectors
93's are 405 motors. 8 will fit, 8 will not.
08-31-2008 | #70 |
Re: Fuel Injectors
They will fit fine (assuming you mean factory stuff from '93). However, since the '93 seals on the end, and the '90-92 seals around the body, you will need new o-rings for the injector housing. They are slighty bigger than stock because the '93 primary body is slightly narrower than the '90. Marc H sells them pretty reasonably, possibly others sell them as well.
I have '93+ injectors in my 1990. You might also want to clean them up a little since now part of the body will be sticking into the sealed or clean side of things.
