Old 06-22-2008   #11
Default Re: Car running like $hit.
I replaced the plugs today and drove it with no problems.Im going to figure on replacing the injectors sooner than later.While Im at it Ill replace the coils and a set of new G.M. replacement plug wires.Id like to have a set of original wires but Im not going to pay $400+ for a set of wires,not me.Thanks for all the tips guys,greatly appreciated.
Old 06-22-2008   #12
jonszr1
jonszr1's Avatar
not sure if you are interested ,but msd makes a very good set of wires for our cars. very low resistance .
Old 06-22-2008   #13
Jeff, I have to agree with your game plan.....not trying to spend your $ for ya...but it's the old "while we're here" rule.
Plenum is off for whatever.....do the right thing before closing it up.
Old 06-22-2008   #14
Default Never say never...
Originally Posted by Nick
That's what I thought, too, until I had only one side of an Accel coil pack fail. The other 7 cylinders were running fine. Good luck.
Your point is well taken. Your situation brings up an anomaly, for sure. However, the "waste spark" system is a "closed" loop (except for the actual plug gaps). That is to say, there is no "one side" of the circuit, per se', Obviously, by your example, it is possible for a weak coil pack to point out a marginal plug or plug wire situation.
Resistance is significantly higher on the compression side cylinder, so in a "gray" situation it is possible, to have that experience if the plug circuit resistance on one side is unbalanced. I would expect, however, that in most cases both plugs would experience some misfire - trading back and forth, especially under heavier loads.
So, that is why I said, I would "put the coil at the back of the line", as far as suspects go: Not to be dismissed, how-some-ever.
P.
Old 06-22-2008   #15
The miss is back,its injector time.Once I find out which is the best injector Ill start rippin.
