Old 05-25-2008   #21
Default Re: euro taillights install
Originally Posted by DaveK
I think the kits from Ecklers and Corvette Central either come with, or have an optional extra, kit that's supposed to make it a plug in operation but I haven't installed either so can't say for sure.
If that was the case thats the option I would use as notbody really wants to splice into their harness unless they have too..
Old 05-25-2008   #22
Originally Posted by GOLDCYLON
Buy another rear harness to cut into?
Thats what Im thinking.Does the rear harness have a plug that plugs into the main harness?Ive always liked the look of the Euro lights and would like to buy a set while you can but Id hate to spend $400+ and then not be able to use them.Cutting wires isnt an option.
Old 05-25-2008   #23
Not sure Jeff I would think so but I have never pulled a rear end clip on a C4 before but im sure somebody here has.
Old 05-25-2008   #24
Jeff maybe Ebay???? Might be worth the $10 to start? 290202401799
Old 05-26-2008   #25
Yes rear harness connects toe the Main Dash Harness and runs to the rear of the car..
Old 05-26-2008   #26
IowaZR-1
IowaZR-1's Avatar
here's the instrustions that come with the Eckler's wiring harness
http://www.ecklers.com/assets/pdf/40372.pdf?
and here is page for the harness it's self
http://www.ecklers.com/product.asp?p...2&dept_id=1499
Eckler's harness is not a plug-in and you'll have to cut or unplug the white wire in underdash modification. This is so the hazard lamps flash thru the amber lamps now instead of the red lamps. I made my wiring harness and have far less than that price. Also with doing the conversion on a ZR-1 you have to tie into the high level stoplight and to do this you have to tie into that harness in the halo(passenger side) or do what I did and tap into the brake applied input on the EBTCM(electronic brake and traction control module) behind the driver's seat.
IowaZR-1 is offline   Reply With Quote
