Old 05-17-2008   #11
UKZR1
UKZR1's Avatar
Default Re: Want to tone down my exhaust overall volume
Anybody tried these???
http://store.summitracing.com/partde...5&autoview=sku
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 05-17-2008   #12
Originally Posted by 95ZR1#418
... P.S. I did have 4:30 gears in the rear end which makes sixth gear so drivable but probably changes the pitch of sound.
Gears make a difference no doubt. I have the B+B 3rd Gen and the drive from BG had drone in it right at the 14-1600rpm range. Anywhere from about 60-75mph with 3.45s. Right now I am scanning the car to see if I can reduce drone thru tuning. I've always found that running a bit lean will "sweeten" and mellow tthe sound at cruise. My 84 with Magnaflow catback, TPIS headers and Random Tech cat had a resonance point similar to the ZR motor. Not much diff and with 3.45 Dana 44, it was at the same rpm. Tuning it helps quite a bit. Looking at the scan, the drone comes in with a 50-65kPa MAP and richer BLMs like 117-122 or so.
P.S. I may be going the LT-4 resonator route, so my B+B resonator could be for sale if someone is interested.
Old 05-17-2008   #13
bradslt5
Originally Posted by UKZR1
yup sure did didnt do a thing except ligthten my wallet . allthough i put them in the cpllector of my headers one might try them else w here
