Old 05-02-2008   #1
Hammer
Hammer's Avatar
Talking Fidanza Question
For those of you that have replaced your DM Flywheel with a Fidanza, I understand you need to replace the stock bolts with longer ones.
How much longer do they need to be? Stock ones are 7/16" x 20 x 2".
Also, where can a person purchase them and the pressure plate bolts?
Thanks
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 05-02-2008   #2
RHanselman
RHanselman's Avatar
Default Re: Fidanza Question
I cannot answer your questions but here's a link to the bolts.
http://www.zr1products.com/products.html
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 05-02-2008   #3
65ZR1
You can use 3 packs of torque converter bolts from ARP. I think they are 7/16-20 by 1.25 long. The part number is 230-7303. This is for the flywheel to crank.
65ZR1 is offline   Reply With Quote
Old 05-02-2008   #4
Thanks
The reference to "longer bolts" that you are probably referring to, actually refers to the pressure plate to flywheel bolts. It's not just longer, it has longer thread engagement in the flywheel but retains the same length of the 3/8" o.d. shank.
The longer thread engagement is a safety issue. Whereas the stock bolts engaged the cast iron material of the stock flywheel, the Fidanza is aluminum, which is significantly lower in yield. Bottom line...stock bolts, torqued to stock specifications are not engineered properly for use in aluminum.
Ron Woods sells a new bolt kit that includes the tap to run the threads through the Fidanza to accomodate longer thread engagement. Expensive, but darn well worth it if you consider the possibilites.
[I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I]
[URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL]
1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc.
Old 05-02-2008   #5
Just installed the Fidanza and that's exactly what I did. Got PP bolts from Ron and bought the ARP bolts for the crank. I sppoke to Haibeck about it and uses the stock bolts but for that extra bit of safety, I went the other way. The ARP bolts are actually for a Flexplate but work fine for the Fidanza.
