04-24-2008 | #1 |
How much should I ask...
As some of the local guys know I'm thinking of selling my 90' Z and looking to move to a lower mile 93-95 Z. I can't buy a new one till I sell this one.
So..... the question is, how much do I ask for mine. Some input here would be appreciated. Here are the details.. 90' Z #1723 Black/Gray 54K miles. Interior is perfect Exterior is good but has some paint chips and flaws consistant with the mileage. The lower rear bumper and the rocker panels could use a repaint. People do however compliment the car on it's paint. The original windshield has no de-lamination. Mods K&N Open Lid & Duct Support, Haibeck Chip, CORSA Cat Back, Hurst Shifter, Drilled/Slotted Rotors, Hawk HPS Pads, Stainless Brake Hoses, 32mm Sway Bar, 170' Stat, Coolant Bypass. Work done in the last two years. New Front Air Dam Headlight Motor Repair Headlights Sylvania Silverstars Driving light upgrade New OEM radiator New OEM coolant hoses 180 degree thermostat New Acc Belt New Delco Ignition wires New Accel fuel injectors New spark plugs New wheel bearing hubs all 4 wheels New drilled and slotted brake rotors / 4 Hawk HPS Brake Pads / 4 Earls stainless steel brake lines / 4 Refinished OEM alloy wheels New Sumitomo tires / 4 VB&P 32mm solid front swaybar with bushings Haibeck chip Throttle body coolant bypass K&N air filter and open housing Haibeck intake duct supports New Battery Inf/Rest light repaired (airbag sensors) New windshield wipers New fuel pumps New fuel filter Cooling system flushed and new coolant New Corsa Exhaust Hurst Billet Plus Shifter New clutch / pressure plate New 2nd gear synchro New door window seals New seat control trim plates repaired seat bladder pumps 2 Drivers seat bolster recovered with original leather 2 replacement power seat mechanisms New console cover 4 replacement Bose speaker amps New ZR-1 floor mats only synthetic oil used only two owners Who ever gets this car will have near fully reconditioned car. I'm thinking of asking $21K...ish. What does the group think? Hans Last edited by Ccmano; 04-25-2008 at 01:50 PM. |
04-24-2008 | #2 |
Re: How much should I ask...
sounds about right. 19-21k .id say ask 21 take 19 then go find your new baby
04-24-2008 | #3 |
25-30k
04-25-2008 | #4 |
Sounds nice, my favorite color combo .
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
04-25-2008 | #5 |
It depends... If you're not in a hurry, I'd want to stick it at $25k and wait for someone that appreciates your car (I've seen it and it is a jewel!).
Or, if you want to "price it to sell", I wouldn't think $21 is anything other than a hell of a bargain - especially since this is a hobby/toy and there's no need to take a blood bath on all the "goodies". I dunno, Hans...I wouldn't be in any hurry to give that puppy away. There are plenty of Zs out there in need of TLC that are going for $21 on down. You know your car, but it doesn't look like a "needs TLC" project to me. Keeping in mind these cars are 13 to 18 years old, moving up 3-5 years may just get you wider seats...(OH! Now, that makes a lot more sense now that I think about it!!! ) You may just be buying someone else's troubles. . Bottom line: I think you should hold out for what it is worth...Somewhere in the $25k "feels" about right, considering all the things done to it. YMMV, P. |
04-25-2008 | #6 | |
Hans |
04-25-2008 | #7 |
do like i did and find another you like . then you get twice the fun .traded my red 90 with 158k and 8 k for a 92 super natural 475 callaway zr1 with 42k miles on her . has everything i wanted to do for the red one . coil over full motor porting 19 lb steel single mass flywheel, 392 gears , brembo brakes ,corsa exhaust, all i have to do is get headers and she is done . i couldnt have done this to the red car for less than17k and i would still have had a 158k car. just take your time and this type of deal will pop up. good luck
04-25-2008 | #8 |
22k
04-25-2008 | #9 | |
Hans |
04-25-2008 | #10 |
I was going down your list of things done to your car and was wondweering what Haibeck intake supports are?
Thanks Good luck |
