Forum Chairman
![]() ![]() Join Date: Feb 2024
I've been been building out a spreadsheet with ZR-1/LT5 parts, part numbers, and hyper links to vendors who either manufacture or sell them. I intend to post the spreadsheet on the forum as a Sticky. It's A LOT of work though and I don't want to re-invent the wheel.
Has anyone done something similar who would be willing to work with me on this?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry forum@zr1netregistry.com 1990 ZR-1 #299, Bright Red/Red |
I go to jerrysgaskets.com for as complete a parts list and supply of parts for the ZR-1 and LT5 as you might find anywhere 👍
His first page lists a complete category of parts that he has available ![]() Jerry is A26B Another member that has provided me many aluminum machined items such as oil filter caps, coolant reservoir caps, 87/91 octane fuel line brackets etc is Carter (Carter200) .......Carter's machining ability is perfection 👍 Another thing you might consider which I have done in my CF Sticky is consider that individual parts sometimes vary a bit in design making the year ZR-1 you have (90,91,92,93,94,95) significant ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 4 Weeks Ago at 04:44 PM. |
![]() Join Date: Oct 2023
There was a PDF file available on the main Registry website at the end of the following page :
https://www.zr1netregistry.com/Infor...tsManuals.aspx But the link is no longer functional. I still have the PDF file if needed. The scan quality is however not that good. Quick search is then not possible. Recreating this document content into a spreadsheet is a great idea. |
I'm new to the Zr1 community and am looking to buy my first Zr1 soon😎(hopefully within the next few weeks).
I'm up for making a spreadsheet out of the PDF. Are you able to send me the PDF? |
Here it is (for registered forum users)
You're not a member (yet), so you probably can't get the attachements. Since this document was from the registry website, could an admin quickly confirm that I can release such document publicly or not ? (via WeTransfer for exemple) Edit : I have issue downloading the file from the forum. Size of the downloaded file is only 16MB instead of 40MB...don't know what's happening. Last edited by RSLyrick; 4 Weeks Ago at 07:37 AM. |
#6 | |
![]() Join Date: Jul 2020
I tried to upload it again, still not working.
Can an admin check what the problem is ? Or confirm that I can just use WeTransfer for this file ? |
Forum Chairman
I have no issue with you making this public and would welcome it! If they are GM part numbers, they will undoubtedly be obsolete by now but will provide a jumping off point for ACDelco replacement part numbers, aftermarket part numbers, etc. Thank you for working this!
#9 | |
Alright then, here we go : https://we.tl/t-T2L8LOgFiF The link is valid for 7 days. The document is digitally signed by a person named K.White if anyone knows. (White Racing Products ?) You will spend your whole life putting this into a spreadsheet ![]() Last edited by RSLyrick; 4 Weeks Ago at 09:04 AM. |
#10 |
Forum Chairman
These sites may be more beneficial. I found them quite helpful. Some of the parts have clickable links that take you to replacement part numbers. Check them out and see what you guys think:
https://chevrolet.7zap.com/en/corvette/48457-1990/ https://nemigaparts.com/cat_spares/epc/chevrolet/14y-y/
