Old 06-15-2022   #1
FailureCoach
Default FS: 94-95 Evaporator Cores
In my mission to find a 90-93 core, Corvette Central, and Old Air Products apparently use the same supplier, they sent me 94-95 Evaps. Neither vendor will return, or even answer my requests for help. So I figure I'll list them here.
They are the correct smaller size core for the ZR-1, but with metric fittings for R-134a equipped cars. The fitting for the pressure switch is the correct placement, towards the outside of the car, not toward the engine like the base model. The unit from Corvette central was installed in the car, but only then did I find out the threads were incorrect. Yes the caps were removed, so they have been open to the air. $150 each obo +shipping. I will likely ship through my work, most likely between $20-30 in shipping. Cost for a new core from Corvette Central is currently $284, I believe I paid $269 around 1.5 months ago.
FailureCoach is offline   Reply With Quote
Old 01-20-2025   #2
ZBrink
Forum Chairman
ZBrink's Avatar
Default Re: FS 94-95 Evaporator Cores
Did you ever find the correct evaporator? Where did you get it? Brand and/or part number? Are these still for sale?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
forum@zr1netregistry.com
1990 ZR-1 #299, Bright Red/Red
Old 01-23-2025   #3
phrogs
phrogs's Avatar
Default Re: FS: 94-95 Evaporator Cores
I have used two used 90 evaporators if you need one.
JOHNNY P
Currently own
Old 01-24-2025   #4
ZBrink
Forum Chairman
ZBrink's Avatar
Thanks Johnny. I don't need one but much appreciate your offer. I was simply trying to flush out more details as I keep reading mixed things about these being unavailable or the incorrect parts yet RockAuto actually still sells them new.
