Old 01-03-2025   #1
ZR1Magic
ZR1Magic's Avatar
Default 1990 Black ZR-1 Barn Find Worth Buying for $9k?
I found a 90z with 20k unfortunately it sat for 8 years (in a barn). I looked the car over the exterior is perfect. Unfortunately the interior has been overrun with mice. I pulled the fuel pump fuse and threw a battery in it. Seems like most things might work again. I know the mice have done a fair bit of damage.....don't know the extent. The owner said it ran fine when parked.
I can snag it for $9k, should I buy it?
ZR1Magic is offline   Reply With Quote
Old 01-03-2025   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: 1990 BLACK ZR1 WORTH BUYING?
Originally Posted by ZR1Magic View Post
I found a 90z with 20k Unfortunately its Sat for 8 years( in a barn) I looked the car over the exterior is perfect. Unfortunately the interior has been overrun with mice. I pulled the fuel pump fuse threw a battery in it. Seems like most things might work again. I know the mice have done a fair bit of damage.....don't know the extent. The owner said it ran fine when parked. I can snag it for 9k , should I buy it?
Yes, provided you have the patience to repair or replace the damage to the harness. The soft goods for the rest of the interior are easily obtained used or as reproductions.
Let us know how you make out.
Marty
Old 01-04-2025   #3
ZR1Magic
ZR1Magic's Avatar
Thanks for the reply! Have to gut the interior replace the carpeting, I would guess? Not sure if there is a way to get rid of the smell of mice urine...etc. The interior is a moldy/ musty mess....checked the coolant and oil....they look very clean.
Old 01-04-2025   #4
DRM500RUBYZR-1
These work!
Marty
Old 01-04-2025   #5
ZR1Magic
ZR1Magic's Avatar
Thanks for sharing!
Old 01-05-2025   #6
Mice can not get inside the ZR1 as far as I know (except in your case) but they do like getting in the coolant reservoir area and on the drivers side in the air induction area and under the plenum which is the worst place to have mice in the engine area.
I use Rodent Sheriff in a spray bottle around the plenum, the two areas each side of tbe radiator and around the battery and windshield fluid bottle.....very effective👍👍👍
I would like to know how mice got inside the car......
But.....like Marty suggests.....The Price is Right 👍👍
Oh.....see you just joined.....Marty and the rest of the gang can help you restore anything on the ZR1 👍👍👍
Old 01-05-2025   #7
ZR1Magic
ZR1Magic's Avatar
Donno how the little boogers got into the car but they did and man they hammered some things. The car can certainly be saved.....alot of work. Will keep you all posted. Thanks for all the comments!
Old 01-05-2025   #8
For the miles and the price can't beat this deal,what color is the car,can you do the work it will need?
Old 01-05-2025   #9
Ask =Jeff= about his 90. Sounds like urs is soo much better off.
Old 01-07-2025   #10
Karl
Karl's Avatar
For $9k I would definitely buy it.
