Old 04-19-2024   #1
scorp508
Question Driveshaft removal for speedo gear swap. C-Beam out or not?
My 94 still has the stock speedometer/vss gear in the transmission even though the D44 has 4.10 gears installed. I have the 13/43 gear from Haibeck to install but wanted to ask a quick question.
His instructions are here: http://www.zr1specialist.com/HAT%20W...on%20Gears.htm
It goes right from remove the exhaust to remove the driveshaft. Is there enough tunnel space to remove the U-Joint strap bolts and get the driveshaft out without also removing the C-Beam? There really isn't in enough room in my '87, but that is an L98 and DN4+3 setup which may be a little different back there.
If I have to remove it that's fine, just curious what to expect. Thank you.
scorp508 is offline   Reply With Quote
Old 04-19-2024   #2
tccrab
tccrab's Avatar
Default Re: Driveshaft removal for speedo gear swap. C-Beam out or not?
It's really tight in there, not a lot of wiggle room between the driveshaft and the c-beam.
Not to say that it's impossible to extract the driveshaft without removing the c-beam, but I'd be really really surprised if you could.
I've never tried.
I could let you know in a couple of weeks, am installing a short shifter on my ZF-6 and everything I've seen says I've got to drop the exhaust.
Once I've done that I'll be able to take some highly accurate (and highly questionable) measurements.
Crabs
Old 04-19-2024   #3
AlbanyBrian
AlbanyBrian's Avatar
My experience with removing the drive shaft is that it is easier to remove the C beam bolts and move the rear of the C beam over. It can depend on your car as there are some production variations and some it maybe possible to get the driveshaft out with the C beam in place. You can always try first once you get the exhaust out and see if you can find a position that will allow the drive shaft to come out.
AlbanyBrian is offline   Reply With Quote
Old 04-19-2024   #4
Mikey
I have had the driveshaft out many times but never without sliding the c-beam back. It is a pretty easy job but I do have a lift.
Old 04-20-2024   #5
HAWAIIZR-1's Avatar
While you are at it I recommend you just get a set of C beam plates and install at the same time. It is not difficult to move the C beam out of the way if needed.
http://www.zfdoc.com/c4beamplate.htm
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-20-2024   #6
scorp508
Great idea. Getting rid of the top nuts alone is worth it. I hate dealing with those.I?ll give Bill a call.
Old 04-20-2024   #7
phrogs
phrogs's Avatar
Damn what am I doing? I've never had to move the c beam to get out a drive shaft in or out.
JOHNNY P
Currently own
Old 04-20-2024   #8
scorp508
Share your magical ways.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 04-20-2024   #9
tccrab
tccrab's Avatar
Saws-all with a metal cutting blade?
Crabs
Old 04-20-2024   #10
phrogs
phrogs's Avatar
I put transmission in neutral then pop rear u joint out of the rear, slide yoke fwd to make room and turning the driveshaft so the ujoint end clears the rear end to the left and wiggle it out.
Sometimes I will loosen to parking brake cable frame mounts to get the cable out of the way.
I just did this I had a rear main leaking and swapped my transmission.
I should have made a video.
JOHNNY P
Currently own
Tags
4.10, gear, speedo, vss
