Old 01-07-2024   #1
rosseich
Question Oil in Plenum
I have a '95 with 9,500 miles and just pulled the plenum. There was oil residue in the runners and oil also drained from the PCV port in the plenum. All the hoses are original, and the PCV hoses were oil soaked. Any ideas?
rosseich is offline   Reply With Quote
Old 01-07-2024   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Oil in Plenum
Some oil in the plenum is not unusual for a normal running LT5 engine with original PCV system. You might check the injector housing gaskets for any seepage. Otherwise provided oil consumption is not a concern wouldn't worry about it.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-07-2024   #3
HAWAIIZR-1's Avatar
These cars will always have some oil residue in the PCV system. This car needs to be driven for sure and the worst thing is sitting. Is your PCV hose that houses the valves soft like a noodle and collapsed? They get old and soft so it wouldn?t hurt to replace it and the PCV valves. If trying to NCRS then keep all your old parts. I?m removing the PCV system with a catch can that has an integrated PCV system. I don?t like the design on the LT5.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-08-2024   #4
tccrab
tccrab's Avatar
Jerrys Gaskets has all the PVC hoses in stock:
https://www.jerrysgaskets.com/pcv-system-emissions/
A little oil is ok, a lot would be indication that something isn't quite right.
Crabs
Old 01-15-2024   #5
AndrewL
All of the above, but also check the coalescing filters are still in place in both cam covers. The filters help manage oil vapor from the cam covers that is vented into the throttle body. When I got my car and checked them, one side didn't even have a filter at all.
File Type: jpg Screenshot_20240115-204325_Gallery.jpg (172.5 KB, 55 views)
AndrewL is offline   Reply With Quote
