Old 08-22-2023   #1
Prez1967
Default Temp goes from 200 to 225 when A/C is on
I cant recall if this was the case since I bought my car but I recently noticed that when Im cruising around without A/C, the car is at a stead 200-202 degrees.
When I turn the A/C on, the car's water temp creeps up to 223-225.
Is this normal? or do I have to roll my sleeves up and dig in...
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 08-22-2023   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Temp goes from 200 to 225 when A/C is on
What radiator do you have installed?
What temperature are the fans programmed to come on?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-23-2023   #3
Prez1967
I have an aluminum radiator in the car now. I flushed it not long ago when I did suspension work and steering rack since I removed it and Haibeck also flushed system when it was up with him at the beginning of the year.
He also programmed the car to run fans at 160 or 180 I think? Whatever his standard practice is.
1994 #353 "Bluey"
Old 08-23-2023   #4
Haibeck both fans on 205 off 200.....
What was air temperature?
What was engine rpm? You say cruizing so must be over 2,000 rpm unless you are in 6th....
With AC on engine temp may rise a bit...
Old 08-23-2023   #5
Prez1967
Got my stats mixed up.
T-stat is either 160 or 180 (dont remember) fans are set to whatever Marc's standard set up is.
Intake Air Temp?
It was SUPER hot a couple weeks ago when I was driving around in heavy traffic and with the A/C off, the temperature was stable at 200 degrees. When I'd click on the A/C it would stabilize at 225. Same result when I was going highway speeds.
It was considerably cooler the last time I drove the car had the same results.
Im planning on driving the car tonight. Can check air temp tonight and report back
1994 #353 "Bluey"
Old 08-23-2023   #6
Young1
Young1's Avatar
I am experiencing the same thing as OP. Never have before. All is clean. Is it possible 30 year old thermostat is not fully opening? I ordered an NOS Stant 14068 on eBay today.
Steve Young
Second Owner
SOLD
SOLD
Old 08-24-2023   #7
Marc Haibeck suggested at one time the older Stants will deteriorate (Decrease in FUll Open Area) by up to 15% as they age. A thermostat with over 50k miles generally opens 5 degrees later and opens about 85%.
Old 08-24-2023   #8
longhorns05
longhorns05's Avatar
I tried a Stant t-stat 3 yrs ago, it never worked right out of the box. The car consistently ran hot until I swapped it out. Especially being in FL, it might be a good idea to look into a lower temp t-stat from Marc or Corey
longhorns05 is offline   Reply With Quote
Old 08-24-2023   #9
Young1
Young1's Avatar
Well, if Marc says it I believe it. I was only guessing but the Man knows. At 75k miles I am due for replacement. I will follow up after I install it.
Steve Young
Second Owner
SOLD
SOLD
Old 08-24-2023   #10
longhorns05
Have you checked to make sure both fans are running when this happens?
