Old 07-25-2022   #1
Jetjock
Jetjock's Avatar
Default Coolant Bypass from Marc Haibeck
Does anyone have a picture of the coolant bypass installed that Marc sells? I bought one and I'm kinda of a visual type. I want to see what it's supposed to look like. Thanks.
Roy
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 07-26-2022   #2
JT ZR-Won
Default Re: Coolant Bypass from Marc Haibeck
This should help...
JT ZR-Won is offline   Reply With Quote
Old 07-26-2022   #3
Jetjock
Jetjock's Avatar
Originally Posted by JT ZR-Won View Post
This should help...
Cool. This helps a lot. Gorgeous motor! Thanks.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 07-26-2022   #4
I presume you saw the picture of the tube itself on Marc's website, but if not here it is. --Bob
Old 07-26-2022   #5
Hobbes
Difficult to get a good picture installed since most of it is hidden, but hopefully these help a bit.
1991 ZR-1 Dark Red Metallic/Black #1648 Stainless Works headers, OBX cat-back, Haibeck chip, Haibeck 170 degree thermostat, throttle body coolant bypass, led headlights & fog lights, Etoile 455 3-piece wheels.
1973 Stingray Black/Black #421. ZZ4 with Holley Sniper EFI, Tremec TKO-600 5 speed, 3-row aluminum radiator, 18? Foose legend wheels, + lots more.
Hobbes is offline   Reply With Quote
Old 07-26-2022   #6
Young1
Young1's Avatar
It gets tight in the area of the TPS. Make sure your alternator positive is covered. I had no luck installing it with the plenum on. It?s a good piece. Go for it.
Steve Young
Second Owner
SOLD
SOLD
Old 08-22-2022   #7
Jetjock
Jetjock's Avatar
OK. I have the plenum loose but the question is this: Does the long end go on the right side of the engine because that's an interesting angle and a long hose to go in. Do you trim the rubber hose on the right side of the engine? Kinda wish I could see the installation process. That would answer a lot of questions.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 08-23-2022   #8
JT ZR-Won
Marc Haibeck installed the one I pictured above so I'm unsure. I did my own install of this mod on my old ZR-1 over 20yrs ago long before that custom metal tube was offered. I cannot remember exactly how I did it, but I believe I just bought one long rubber hose and ran it from one end to the other underneath the plenum.
Jay
Old 08-23-2022   #9
Hobbes
Roy
The less bent end is the drivers side. Once in place, and before you attach the hose, you use a #2 Philips screwdriver to bend that side down a bit to more resemble the passenger side. As for the hoses, I ended up getting a length of hose at Napa and making some shorter length pieces to fit both sides better.
Old 09-02-2022   #10
ZWILD1
ZWILD1's Avatar
Marc did a 510 package and he cleaned up the look .
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
