05-23-2022 | #1 |
Dump valve Exhaust project
Step (1) cut apart a perfectly good Billy Boat fusion exhaust system and pray you made the right decision....Screenshot_20220502-065620_Photos.jpgScreenshot_20220502-074024_Photos.jpg20220509_185929.jpg20220509_195648.jpg20220510_211941.jpg20220512_123413.jpg
The older I get the faster I was. |
05-24-2022 | #2 |
Re: Dump valve Exhaust project
Step. (2) Everything is cut and mocked up, ready to weld.20220510_211928.jpg20220510_210123.jpg20220510_202435.jpg20220510_210053.jpg
05-24-2022 | #3 |
Looks great--I did something similar on my '95. I wanted a stock exhaust for the appearance and lack of drone, but with cutouts to have an open exhaust when I wanted it. I usd QTP electric cutouts and hid a rocker switch under the carpet on the passenger side of the console. Located the cutouts right in front of the mufflers to preserve the spare tire carrier. Either your way or mine works well. --Bob
05-24-2022 | #4 |
http://www.zr1.net/forum/picture.php...pictureid=3053
In 216 I had power effects exhaust system and a friend waned it for his car. I told him give me some time to fab up a new system. Long story I got a used LT1 exhaust system, added dual dumps with QTP electric ( I removed the spare tire assembly as I run a transmission cooler in that location). Have been running this setup since mid 2016, I get good comments from everyone who sees and hears it. John 1990 white/black # 2546 one of a few 4l8OE QE ZR-1"s |
05-25-2022 | #5 |
Hey aafc
What is the red cable in the pic? Never mind. Suspect for trans cooler.
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! Last edited by tf95ZR1; 05-25-2022 at 02:19 AM. Reason: Duh: Then Read Post |
05-27-2022 | #6 |
I'm going with the full wireless module set up. Super small, smaller than a pack of cigarettes really concealable. Just needs 12V and a ground and comes with two key fobs.20220519_195731.jpg
05-27-2022 | #7 |
When I tried to adapt the Mild to Wild setup for my Z06 NPP valves, I ran into an interesting anomaly. If I fed power to the vacuum solenoid from 12v battery, the system worked. However if I fed power from the car?s electrical system, it would not work. The only thing I could come up w was that the vehicle electrical system somehow interfered w the wireless signal. Ultimately, I just ran wires to the back where the solenoid is located and a rocker switch in the console cup holder.
05-27-2022 | #8 |
This valve set up is completely electric. Should be finishing up the install this weekend.. 20220512_123404.jpg
05-27-2022 | #9 |
Hi here is what I have done I used the QTP remote as well I made a defuser for landspeed racing quite when you want it and sounds awesome when you're on it I also open the valves just abit when I drive the car it doesn't seem to drone and it sounds good from inside the car a friend rang me one night when I was out cruising around in my car and said it sounds great as I had driven passed him with the valves partially open I have my own headers and 3" exhaust system in front of this 20190811_191918.jpg20190811_174414.jpg20190811_184055.jpg20171216_094558.jpg20180407_111123.jpg
Sent from my SM-G998B using ZR-1 Net Registry mobile app |
05-27-2022 | #10 |
Hi and a drive by at wide open just in case you haven't seen or heard it before
https://youtu.be/eVtmCmN4038 Sent from my SM-G998B using ZR-1 Net Registry mobile app |
