Old 04-07-2022   #11
Flyman 27
Flyman 27's Avatar
Default Re: TSB for Additional Under Plenum Drain?
Originally Posted by Gsgnz View Post
Is it ill advised to drill this hole from the flywheel side?
I would say ill-advised. Too easy to miss the intended target.
I drilled mine 4 years ago with no issues.
The hole is intended to drain water from driving in the rain and from cleaning under the hood.
Cams by Pete
