Old 02-10-2022   #1
lfalzarano
Default Need your ideas - LT5 won?t turnover
The car has been in a shop for 3 months to repair the clutch hydraulics (master and slave cylinders) and replace the clutch. The battery was replaced last week, but the mechanic says nothing happens when he tries to start it (will not crank). The LT5 had no engine problems even after the transmission failures when I drove it last.
I know they must have moved the ECU when they replaced the clutch master cylinder. I also know that you have to disconnect the clutch pedal to the clutch master cylinder when replacing it.
Suggestion on a possible solution would be appreciated.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 02-10-2022   #2
mlipmd
Default Re: Need your ideas - LT5 won?t turnover
Did they disconnect/reconnect the CSS?
mlipmd is offline   Reply With Quote
Old 02-10-2022   #3
lfalzarano
What is the CSS?
Old 02-10-2022   #4
Young1
Young1's Avatar
Clutch safety switch. Mounted on clutch pedal assembly up under hush panel
Steve Young
Second Owner
SOLD
SOLD
Old 02-10-2022   #5
viper107
viper107's Avatar
if they can pull a transmission the shurly can figure this out, no differant than any system
Old 02-11-2022   #6
tccrab
tccrab's Avatar
Nothing special about the starter and ignition circuits, same as all other C4s.
It's not rocket surgery, any decent mechanic should know and understand and diagnose them with both eyes shut.
Vats does complicate it somewhat, but thats why theres diagnostic charts in the FSM.
Sounds like you need a new mechanic.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 02-11-2022   #7
Young1
Young1's Avatar
It?s not necessary to move to remove the ECU, you just remove it from its bracket and flip it over out of the way. If they took all the clips out of the back of the eco and put them back in incorrectly that could be your problem. Again not rocket science.
Steve Young
Second Owner
SOLD
SOLD
Old 02-12-2022   #8
lfalzarano
Thanks but that tested OK according to the mechanic.
Old 02-12-2022   #9
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
1- battery voltage 12.5 plus
2- battery connections clean and tight
3- is it making it through the VATS ( were the two white wires in column harmed)
4- make sure a thicker floor mat is not preventing clutch going to floor
5- any deflection of voltage needle when key turned from on to start
6-unplug and replug ECM connectors if they had been removed
7- If ECM was removed, make sure chip is in firmly and correctly.
Marty
DRM500RUBYZR-1 is online now   Reply With Quote
Old 02-12-2022   #10
Demps
Demps's Avatar
Marc Haibeck's site has his tips...I'd reference this: http://www.zr1specialist.com/HAT%20W...20Problems.pdf
Ted
