Old 01-06-2022   #31
bsneade
Default Re: HEADLIGHT UPGRADE
I just upgraded my headlights, but I used the instructions from a post on Corvette forum.
The reason the ballast is needed is so the fog lights and high beams work correctly. To do that you only need a small amount of resistance, not the full load that the off the shelf resistors take on to simulate the original bulb.
I like his mod because the entire thing can be contained to the bulb itself and no modifications to the car.
Here is the link to my reply where I posted my results. The actual instructions are further up in the thread.
https://www.corvetteforum.com/forums...post1604497463
Sent from my Pixel 4 XL using ZR-1 Net Registry mobile app
bsneade is offline   Reply With Quote
Old 01-09-2022   #32
tstrohl12560
I bought these off of eBay. Plug and play requiring zero modifications. Hi and low beams work perfectly and are at least 3x brighter than stock. Fog lamps work perfectly, and they are very inexpensive. Awesome upgrade to our pathetic OEM lights. Highly recommended!
https://www.ebay.com/itm/393439669184
tstrohl12560 is offline   Reply With Quote
Old 01-10-2022   #33
Matt B
Matt B's Avatar
72 Watts eachs - boy, that's a LOT for LED. Guess these simply can burn other cars off earth's face and thereby help saving fuel otherwise wasted for a full throttle passing maneuver
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Old 01-10-2022   #34
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Likely explains why the fogs work properly with no mods.
That about 50% more watts than stock.
Most LED's are less.
Interesting though.
Thanks for posting!
Marty
Old 01-10-2022   #35
spork2367
I like the stock look of these. A little $$$ though.
https://www.headlightrevolution.com/...5x7?quantity=1
Old 01-10-2022   #36
Figure8it
Figure8it's Avatar
I just ordered these to give them a try. In need of some small projects to get me through the winter.
Figure8it is offline   Reply With Quote
Old 01-11-2022   #37
Matt B
Matt B's Avatar
Very nice, thanks for the hint! Too sad they're not asymmetric.
ZR-1 #638/1991
Old 01-14-2022   #38
Starman
Starman's Avatar
I put the Sylvania Silverstars in my car. Much brighter than original, not too salty and plug and play.
Old 01-17-2022   #39
Prez1967
Have a part number? im not looking to upgrade to LED and like the stock look.
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 01-22-2022   #40
Figure8it
Figure8it's Avatar
Hard to tell which is the new LED 🤷*♂️
