01-06-2022 | #1 |
WTB 93 - 95 oil pan
Does anyone have a 93 - 95 oil pan?
used is preferred..... Thanks John Putting a 1990 motor in a 1994 chassis and want to get around the different side that the low oil sensor is on.... anyone with insight on this would be appreciated... Last edited by wfot; 01-06-2022 at 05:57 PM. Reason: word changes |
01-06-2022 | #2 |
Re: WTB 93 - 95 oil pan
Late, 93~95 Oil Pan will not interchange with EARLY 90~92 models.. Bolt pattern is different & oil pickup is very different.
1990 model did not have a low oil level sensor. 91~92 do have low oil level sensor.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-06-2022 at 08:13 PM. |
01-06-2022 | #3 |
The 94-95 pans have several differences including the oil pickup tube, windage tray and baffling. Bolt patterns are also different. Jerry's shows different gaskets.
01-06-2022 | #4 |
I am aware that there were several bolt that are different but NOT aware about the pick up tube and windage tray.
it is a 1991 to 1992 as it has a sensor port in the side, thank you Jerry. what to do then, I have to use the 1991 pan, Are the wires in the harness long enough to reach the other side?? I am going to bet NO and I really would not want to route wires under/around the pan anyway. Is there a way to extend the wires properly? John |
