Old 02-17-2008   #1
32valvZ
32valvZ's Avatar
Default So how hard is putting in a set of Samcos?
Getting ready to buy a set of coolant hoses & wonder how much of the car I will need to disassemble to get to the lower hoses. I can get the spring clamp pliers from Sears/Craftsman.....will these work? Any tricks to refilling the system?
TIA
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 02-17-2008   #2
Hammer
Hammer's Avatar
Talking Re: So how hard is putting in a set of Samcos?
Just a few tips.
I used NAPA brand antifreeze, with the silicates in it. It needs to meet 1825-M or M-1825 spec. Whatever is in the book is what spec you need to have on the can.
Flush with distilled water only and then pour in the antifreeze straight for half the capacity, then top off with the distilled water. DOn't remember how many gallons of distilled water I got. Something like 5 or 6.
Remove the radiator shroud by pulling the driver side up first and then just screw around with it until you get it out. Reverse the three clips for the bolts on each side at the front before you put it back on.
Use a little dielectric grease on the hoses and they slip right on. Don't use a lot, just a bit.
If you are replacing the thermostat, use the bracket that attaches the housing to the frame on one side and a putty knife on the other to hold the thermostat in place while fastening the cover down. Two people makes this easy.
That's it. Everything else will just be standard mechanic stuff.
Oh yeah, replace your serpentine belt while you are there too.
Do a search, there should be a lot of info here.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 02-18-2008   #3
cuisinartvette
Default Re: So how hard is putting in a set of Samcos?
Tstat housing, clamp on water pump may be a PITA to get off. Its going to take some patience..Getting the tool for the clamps was a good move on your end which will help. Unless they are positioned just "wrong" that will speed things up.
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
Old 02-18-2008   #4
Aurora40
Aurora40's Avatar
Make sure the craftsman tool you get is the remote one, the one on the long cable. Not the one that is pretty much like a set of normal pliers, just with a different end on it. Some of them clamps can be in odd positions, and the remote tool helps a lot with that.
I second the small dab of silicone grease on the new hoses. Otherwise you'll never get them to slip on. They will appear too small at first, but they'll get on with some grease.
The only things I believe I disassembled were the accordian duct, the serpentine belt, and the belt tensioner. You could also remove the TB extension if you wanted, though I don't recall it being in the way too much.
Bob Saveland
Former owner of #2517
Old 02-18-2008   #5
32valvZ
32valvZ's Avatar
Thanks guys....I have the whole top end off the car still waiting on a good secondary actuator to arrive.. , so the air horn is off already & I figured why not? Just get it done & over with now. I already have a new serp belt.. I'll pick up a T-stat today & some distilled water.
Aurora, not familiar with the tool you describe. They only have the plier like set....I'll check NAPA & CarQuest...
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 02-18-2008   #6
Aurora40
Aurora40's Avatar
They look like this:
They might also have them from SK if they carry that locally, though the SK ones are more expensive (though probably better quality).
Bob Saveland
Old 02-18-2008   #7
Zr1 Destroyer
Zr1 Destroyer's Avatar
TIA
It's a knuckle beater for sure....lol! The only hose that gave me a fight was the little straight hose on the bottom for the thermostat housing.
Good luck with yours and what color did you get?
Zr1 Destroyer is offline   Reply With Quote
Old 02-18-2008   #8
Zr1 Destroyer
Here's a few pics before i changed mine over to the Samcos. This little cross over pipe is also real fun unless you plan on removing the radiator.
I had to trim the Samco piece down a little bit!
Old 02-18-2008   #9
Jeffvette
Ry, you would have to trim down the stock piece as well since you have a aftermarket radiator.
The bottom crossover is easily accessible from underneath the car. The clamp is supposed to be positioned that it can be reached from that point.
There is no need to remove the rad.
Old 02-18-2008   #10
32valvZ
32valvZ's Avatar
Hey Ry....ths for the pics. I got her all torn apart & cleaned up today. I got red ones. Yea, it kinda sucked, but not a huge deal. I wound up pulling the radiator out & glad I did....look at the pics. The bottom is really out of shape & looks like one of the coolant passages (second up from the bottom) is ballooned up & distorted. The whole area really needed cleaning anyway.
engine side
condenser side
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
