Old 08-16-2021   #1
bowtiguy
Default Silicone hoses. Mishimoto - or- Samco
I used mishimoto hoses on my 99' FRC and was impressed with quality & fit. The lettering was easily removed with acetone and some elbow grease.
I'm doing a full cooling and 134a A/C redo on my 91' this winter and am in the process of shelving parts for the process. Jerry is out of stock and the back order is TBD.
Anyone fit the Mishimoto silicone hoses to an LT5?
bowtiguy is offline   Reply With Quote
Old 08-16-2021   #2
1991 Corvette ZR-1
Default Re: Silicone hoses. Mishimoto - or- Samco
Another option you may have is Marc Haibeck. He should still be offering the traditional coolant hoses that look like factory pieces. That is unless you?re looking for the unique finish silicone hoses have. I?m curious about your conversion as my system is leaking and I most likely need to convert over as well this winter.
Old 08-17-2021   #3
HAWAIIZR-1's Avatar
You can find SAMCO hoses from various sources. Ref the part number in your search.
http://www.2kracing.com/Product/67706.html
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-17-2021   #4
SAM/CH ZR-1
I use hoses from SAMCO and never had any issues.
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 08-17-2021   #5
bowtiguy
Attachment 16022
Thank you sir!
Good to hear. I'm a "do it once" kind of guy.
If I'm spending that much, I'll go silicone.
I'm pulling all my R12 gear out and replacing with R134a "while I'm in there". I used up all my R12 on my NCRS 91' ZR-1, I'll post up a thread of current part#'s once I can verify fit and function.n ( basically a 93-95 system). Its the evap core I'm not looking forward to.
Old 08-17-2021   #6
DaveP
2kracing no longer carries samco. I called them 20 minutes ago.
I found two more vendors online, both had the ZR-1 kit listed "discontinued".
These may be unobtanium now.
DaveP is offline   Reply With Quote
Old 08-17-2021   #7
Karl
Karl's Avatar
I have used Mishimoto silicone hoses on both my ZR-1's and they performed flawlessly.
I used the factory hose clamps to secure everything.
Good luck.
Old 08-17-2021   #8
SAM/CH ZR-1
Samco hose kits are made to order. The typical time at present is around 10-12 weeks.
Sam
Old 08-17-2021   #9
HAWAIIZR-1's Avatar
SAMCO are made in the UK. You probably have to contact one of their distributors and special order like SAM/CH ZR-1 said. Damn, a lot of parts are becoming unobtanium. I hope my set lasts until I sell the car.
https://samcosport.com/product/corve...5-7ltr-v8-32v/
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 08-17-2021   #10
HAWAIIZR-1's Avatar
Hopefully Jerry is finding a source to make these in the US.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
