Old 07-14-2021   #1
Erik
Default How Hard to Pull the ECM? Haibeck Chip Install Question.
What's involved in pulling the ECM? I have a Haibeck chip that needs to be reinstalled, and wasn't sure what was involved in getting the ECM out to do so.
Also, when the ex-mechanic installed the Haibeck chip previously, it came loose and rattled around inside the ECM box. Now, it seems to lock in pretty securely, but he had also commented that it was tough to get the chip in. Doesn't make much sense to me as it just clicks in.
Any thoughts?
Old 07-14-2021   #2
Default Re: How Hard to Pull the ECM? Haibeck Chip Install Question.
Any thoughts?
U need to take off the blue cover from the prom in order for it to fit in the ECM case.
Old 07-14-2021   #3
Erik
It looks like this now, in my spare ECM:
File Type: jpg 60DB4C89-1E74-4A3C-9BD7-628153D1101A.jpg (91.7 KB, 23 views)
File Type: jpg BE8F911F-35CF-4621-9C76-3DEC4973FECE.jpg (65.0 KB, 20 views)
File Type: jpg 98BD549F-9EF5-4D59-8A8B-E4A853CFA68F.jpg (68.8 KB, 17 views)
Old 07-14-2021   #4
PhillipsLT5
PhillipsLT5's Avatar
http://www.zr1specialist.com/HAT%20W...librations.pdf
last 4 pages
Old 07-14-2021   #5
Erik
Originally Posted by PhillipsLT5 View Post
Thanks.
Doesn't really show what's involved in removing the ECM though.
Old 07-15-2021   #6
PhillipsLT5
Unbolt, flip over, install
Old 07-15-2021   #7
Erik
Easy enough. Thanks
Old 07-15-2021   #8
tccrab
tccrab's Avatar
Be sure to remove the negative battery cable before doing any work to the ECM.
'Crabs
Old 07-15-2021   #9
Erik
'Crabs
Thanks.
Just the kind of info I was hoping for!
