Old 07-14-2021   #1
randy ransome
randy ransome's Avatar
Default Lowering Front End
I lowered the front of my 95 ZR-1 a few years ago. I've decided it's too low. I cut the rubber on top of the Mono leaf spring. I can't remember how much I cut off. I'm hoping some one can tell me the thickness of the factory rubber that is on a stock spring.
Thanks for any help.
Old 07-14-2021   #2
Erik
Default Re: Lowering Front End
If no one has the info, I can go and measure the spring in the garage. How low is yours now? Is it grounding a lot? I was just looking to trim mine back before installing the springs, so your input would be appreciated.
Btw, any pics?
Old 07-14-2021   #3
randy ransome
My car is only 2 1/4 inches from the road up to the brackets below the radiator that are there to keep you from bottoming out the frame. Too Low.
Old 07-15-2021   #4
Erik
Agreed. That is too low!
Someone else recommended recently hacking off the rubber spacers, and they had better results then you did. I'll have to dig that up.
