Old 06-25-2021   #11
Default Re: Rattles inside and outside the car...
Having owned 2 ZR1s since 1991, I know a few things about squeaks and rattles in ZR1s.
I fully sympathize and understand Marty's sentiment. However, there are a lot of squeaks and rattles that can be tamed.
ram_g,
I would remove radio bezel, remove radio, try wrapping harnesses behind with thin foam and zip-tie and tuck in as radio is reinstalled. Be sure to tighten 4 hex bolts (In think M8s) without stripping since these bolts fasten into plastic and not metal.
Also, be sure that radio bezel is bolted in tight all all points.
If it still squeak and rattles, turn to Marty solution.
Old 07-01-2021   #12
cadillac531
cadillac531's Avatar
ram_g,
Thank you. I'll be removing the radio soon to have it serviced and I'll address that.
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 07-01-2021   #13
cadillac531
Originally Posted by DRM500RUBYZR-1 View Post
Best solution that I have found with 25 + years of ZR-1 ownership to overcome the squeaks and rattles is to absolutely go with the loudest most aggressive exhaust that you can find.
Yes, it will drone.
Yes, your neighbors may frown at your 5 AM startup on drive days.
You may need a couple of Excedrin.
HOWEVER, the smile on your face during each drive will be a lasting treasure.
It is now an older Corvette, AKA Born to Rattle.
If you want quiet, drive the Lexus.
Enjoy the drive, rattles and all!
Marty
Seems like a pretty easy fix then.
Constantine
