Old 06-14-2021   #1
dmaclennan
dmaclennan's Avatar
Default WTB: Clutch & Pressure plate for 1991 ZR-1
I know it's a long shot. Jerry's Gaskets don't have any. Anyone else out there know where I could find these.
dmaclennan is offline   Reply With Quote
Old 06-15-2021   #2
wfot
wfot's Avatar
Default Re: WTB: Clutch & Pressure plate for 1991 ZR-1
I have a used fidazna flywheel I think I will be selling soon. I got a new dual disc and probably will not need it anymore, if you are interested.
FYI, the flywheel and pressure plate are the same for all years, the throwout bearing is the thing that changes. it depends on the diameter of the transmission tube around the input shaft. being a 1991, assuming it stock, you should have the larger diameter tube on yours. SO any LT5 flywheel will work, any LT5 pressure plate will work, just make sure you get the correct throwout bearing.
wfot is offline   Reply With Quote
Old 06-15-2021   #3
I understand that you are trying to acquire original equipment, DM (dual mass) flywheel & clutch components.
In the event you are not successful in your quest, Jerrys Gaskets can supply used, OE DM Flywheels. While we do not have replacement OE pressure plate & disc, we can supply a RAM conversion Clutch kit to be used with the DM Flywheel. Installation does require a simple modification to the Bellhousing. The RAM Clutch conversion kit eliminates the need for the original (1) Slave Cylinder, (2) Clutch Fork and (3) Clutch Release Bearing.
If you consider replacement of the DM Flywheel, Jerrys Gaskets can furnish any 1 of 4 different SM (single mass) Flywheels for your application with the RAM Single Disc Clutch Kit, all depending on your choice for intended driving style.
You do have options that Jerrys Gaskets can assist you with.
Old 06-15-2021   #4
dmaclennan
dmaclennan's Avatar
Thanks Jerry. I expect I'll be going with your RAM conversion kit. The reason for trying to stay OEM is the potential noise issues. This car has no mod's and is not raced. It does get some lively driving when I'm solo What RAM mod would you suggest?
Old 06-16-2021   #5
As usual, Jerry is the man to see for both parts and great advice. --Bob
