04-25-2021 | #681 |
TB removal and then some!!!
Hey Tom,
What was the condition of the inside of your coolant crossover pipe? Mine was rusted inside. My friend in Japan had coolant squirting out from pin holes due to rust. Sent from my iPhone using ZR-1 Net Registry
04-25-2021 | #682 | |
Re: TB removal and then some!!!
Sent from my SM-G981U using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 04-25-2021 at 11:22 PM. |
04-25-2021 | #683 |
Craig....just some minor surface rust...should have checked better before I painted....lol....will get some sandpaper and tape around the head of a long screwdriver and sand the inside of the pioe....just to be sure....20210425_145430.jpg20210425_145451.jpg
04-25-2021 | #684 | |
Tom, That is good news. I think you will be okay and mine was just sitting too long and maybe too much water (distilled) with 50/50 mix. His was spitting out the pin holes only when pressurized. Luckily I had an extra crossover pipe to send him at the time. I am going stainless from Phil. When I move back this will be my last before retiring so no more sitting Z and then some...... Sent from my iPhone using ZR-1 Net Registry
04-25-2021 | #685 | |
Yours is beautiful compared to mine a few years ago. Image1619377575.641845.jpgAttachment 1 Sent from my iPhone using ZR-1 Net Registry
04-25-2021 | #686 | ||
04-25-2021 | #687 | |
Yes Sir! I am 3-5 years away from retirement. Yep, I already replaced the one shown. Sent from my iPhone using ZR-1 Net Registry
04-26-2021 | #688 | |
04-26-2021 | #689 |
Someone just mentioned to me that the JB Weld will eventually break off from the repair area in the future and cause problems.....as you can see...the area circled is the repair area I sanded down after taking this pic....I can drill it out and round off that area...and just leave it opened without the JB Weld.....as it will be covered by the hose down to the straight line shown...as we all know....which won't be leaking when attached...
Any thoughts on using the JB in the cooling system??? 20210425_120223.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
04-26-2021 | #690 |
Should be no problem if it's on the outside.
