Old 04-25-2021   #1
ram_g
Default Additional wire to blower motor control - picture??
I want to do the mod that Haibeck mentions here - running a parallel wire from the battery to the blower motor controller to reduce the voltage drop at the blower:
http://www.zr1specialist.com/HAT%20W...the%20ZR-1.pdf
Does anybody have a picture of what this looks like at the blower motor controller end? Do you simply splice into the existing red wire close to the connector? Or does the connector get repinned in some way?
At the battery (+12 distribution) end, do you use a fuse?
Thanks!
ram_g is offline   Reply With Quote
Old 04-25-2021   #2
ram_g
Default Re: Additional wire to blower motor control - picture??
Nobody? Someone must've done this...or had Marc do it for them?
Old 04-25-2021   #3
I spliced it on close to the connector and insulated it with heat shrink.
Old 04-25-2021   #4
ram_g
Thanks, Yun! Did you use a fuse at the other end, if so what amperage?
Old 04-26-2021   #5
dredgeguy
dredgeguy's Avatar
Here you go, just popped the hood and took some photos and hope it helps.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-26-2021   #6
ram_g
Thanks!!
Old 04-27-2021   #7
I considered splicing in fusible link but did not. Looking at Charlie?s Z, Marc did not splice in any fuse nor fusible link.
Old 05-02-2021   #8
ghlkal
ghlkal's Avatar
Thanks X2
I am considering doing this also, so I appreciate the pics
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 05-03-2021   #9
Roadster
Roadster's Avatar
Reading the article and the recommendation from Marc about the 200 amp alternator and going with the 2.6" pulley.....I have a 200 amp on my 94 with the stock pulley which is 2.8" plus depending on how you determine the measurement.....so from what I understand....is that you need to use the 2.6" pulley with a 200 amp alternator.....just need clarification......thanks for any info.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-03-2021   #10
dredgeguy
dredgeguy's Avatar
I believe Yun did the pulley change with the 200 amp alternator. Marc kept my pulley stock and just went with the 200 amp alternator. It makes a good difference in the amount of cold or hot air flowing out the vents. According to Marc, went from 10mph to 14mph!
Charlie
__________
Dredgeguy
Dana 4:10 gears
