Old 10-03-2020   #1
Rodney McDaniel
Default Irradic idle
Hi guys , 16 new injectors (fic ) new gm coils, new plug wires , seems somewhat better, still have irradic idle when idle is coming down. From higher rpm. Any suggestions
Rodney McDaniel is offline   Reply With Quote
Old 10-03-2020   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Irradic idle
What year?
Original Chip?
Marty
Old 10-03-2020   #3
One never should assume a replaced part, being "new', is therefore exempt from suspicion. Bad, bad, bad mistake! (In fact, the period in a device's life when it is MOST LIKELY TO FAIL is when it is first put into service: statisticians call it "infant mortality".)
A good place to start is with an OBD-I scan, with particular attention to Throttle Body voltage, BLM and INTEGRATOR values, O2 readings and dwell time (left vs. right), etc. Are the plugs new, and if so, what are they and what gap are they set at? I (we) might assume it is closed loop when the issue is present, but is it?
All things to know before attempting to throw more parts at the problem...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-03-2020   #4
tccrab
tccrab's Avatar
And he needs to exactly define what the "erratic idle" is that he is wondering about.
If it's the emissions hesitation from ~1200rpms then down to idle at 700rpms a few seconds later, then it's a condition and not a symptom.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-03-2020   #5
'Crabs
Yeah. Very good point! Just what zackly R we talkin' about here, Rodney?
90 #1202
Sans secondaries
Old 10-03-2020   #6
Rodney McDaniel
Hi, that was pretty vague. It's a 91, stock chip that I know of, Watson long tube headers, 3 inch B&B exhaust no cats. The original problem was varying idle speed about 500 to 1500 rpms, car started good, after a couple min. warm up about a mile from my house it would start bucking , missing like it ran out of gas. This is in the 2 to 3 thousand rpm range, 20 - 30 mph, push in the clutch turn the power key off, motor not running let the clutch out and it would chug back to life then run fine. Installed new fuel filter, new fic injectors, all new viton orings, car has 2 new fuel pumps. So while I was under the plenum I installed new gm coils,& wires. Testing fuel pressure 50 psi. Car has only cut off once since, that time the power key was off. Still has varying idle speeds + sometimes it idles at 2- 3 grand. Sometimes it idles fine ???
Old 10-04-2020   #7
dredgeguy
dredgeguy's Avatar
Hi Rodney, great meeting you at Hunt Valley cars and coffee yesterday. Sure that our forum brothers can get this sorted out for you and hopefully we can have a Wazoo maintenance day soon as well.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 10-04-2020   #8
Rodney McDaniel
Yeah. Hi Charles, it was nice meeting you and your daughter yesterday. Looking forward to meeting more members, and hanging out at a Wazoo maintenance day.Thanks.
Old 10-08-2020   #9
I wouldn't (ever) throw parts at a problem. Not only is it expensive and time consuming, but often frustrating when you guess wrong (new part didn't fix it). AND, then there's always the how was the old part performing vs. how the new part is (now) performing? (The most failure prone period in a part's service life is when it is first installed [and now that so much stuff is out of China where QC is often vague at best, so much the worse for infant mortality]. And, this fact often complicates troubleshooting as it may introduce ANOTHER problem - compounding the whole attempt to fix an issue!)
Scanning is going to be your best bet to zero in on what is/isn't working. In particular I'd want to know what the O2 sensors (left and right) are doing, the BLMs and INTEGRATOR and IAC counts and % throttle was doing.
Beings your in WAZOO land, your in good hands, as Charlie said!
90 #1202
Sans secondaries
Old 10-08-2020   #10
How many miles on motor? May want to pull IAC and clean the pintle and the TB opening where it fits.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
