09-28-2020 | #1 |
Cluster LCD pulsing
Hey gang,
So I was sitting at a stop light the other day and noticed that the center square LCD (the one that has the speed on it) was pulsing. It doesn't seem to be in line with the turn signal clicking. I tried taking a video of it, but the camera can't really pick it up. Battery was fully charged up two days ago (trickle charger for 8 hours), and the battery is only 6 months old anyway. Initial thoughts? Anything I need to worry about?
1967 Corvette convertible, L79, 4 speed, red / black / white top 1994 Corvette ZR-1, white / black NCRS North Central Chapter Judging Chairman |
09-28-2020 | #2 |
Re: Cluster LCD pulsing
check charging system?
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
09-28-2020 | #3 |
My 97 Suburban does that as well, I'm positive it's the alternator in mine.
09-28-2020 | #4 |
My 91 did the pulse. Then the alternator rotor came apart at high rpm. New alternator no more pulse.
09-29-2020 | #5 |
I did a little reading online, as it has been a bit since I have done any alternator testing on my own. Is the process still this?
1. Start car 2. Disconnect battery 3. Car should run with alternator and not die?
09-29-2020 | #6 | |
Here is a simple procedure to follow... I found this in my first search... https://www.wikihow.com/Check-an-Alternator
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
10-02-2020 | #7 |
I checked the voltage across the battery prior to starting the car. I had driven it twice the day before, no issues. The voltage was 12.5. I started the car and backed it out of the garage and tested the voltage again with the car running. It was steady at 15. I'm assuming this is ok.
10-02-2020 | #8 | |
10-02-2020 | #9 |
Ok thanks. I'm heading on a three hour trip with the car in a couple weeks and just wanted to make sure everything was OK.
10-03-2020 | #10 |
No secrets surrounding lead acid batteries (including AGMs). But, to your fluctuating illumination question:
Fluctuation of the dash (LCD) screen is due to fluctuating current which can be detected indirectly by monitoring voltage. Some facts about (car) batteries: Each of the 6 cells at rest and fully charged produce 2.1 volts and are series connected to produce 12.6 volts at rest when fully charged. A 12 volt car battery that measures 12.1 volts at rest is fully discharged, far as working to capacity goes. NOTE: A 12 (car) battery with a shorted cell will read ~ 10.5 volts, even after having been charged sufficiently to normally charge the battery fully. However, a battery can read much lower too if allowed to become severely discharged, e.g., leaving the headlights on over night. A battery discharged (I've seen some as low as 1 or 2 volts after the headlights ran the battery down over night. The battery's capacity to be restored to full (current load) With the engine running and the headlights OFF, normal charging voltage is 14.6 volts, when the engine bay is cold, i.e., engine is first started and will recede to approx 13.8 after the engine bay heats up and the battery capacity if fully recovered after starting the engine is complete. The capacity of a battery can only be done once it is fully charged and then the voltage measured after a specific time while a specific load has been applied to the battery. (Even a fully discharged "dead" battery will read 12 volts!) So! with all that in mind, onto the fluctuating LCD (dash) light...
Good Luck! P.
