Old 06-29-2020   #1
32ValveGuy
Default Oil Change
Hello Guys,
My oil change light came on which begs the question: Do I continue with using conventional oil or switch to synthetic? I have a little over 40k miles on it. If I do switch what is the procedure?
Thanks in advance
Joel
32ValveGuy is offline   Reply With Quote
Old 06-29-2020   #2
Default Re: Oil Change
Originally Posted by 32ValveGuy View Post
Hello Guys,
Thanks in advance
Joel
I would switch over to full synthetic. I used Mobil 1 high mileage until about a year ago when I found out Mobil quietly reduced zinc and phosphate from 1100 to 800. Since then, I have been using Amsoil Z-rod 10-30.
Just my opinion and decision.
Old 06-29-2020   #3
PhillipsLT5
PhillipsLT5's Avatar
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
https://www.amazon.com/Mityvac-7201-...-1&tag=mh0b-20
http://www.zr1specialist.com/HAT%20W...ers%202006.htm
Old 07-01-2020   #4
Young1
Young1's Avatar
Brad Penn synthetic blend 10/30 is reasonably priced and has a zinc level of 1500. I get it on Amazon. Even mixing with 2-3 quarts that don?t drain from the pan will leave you with plenty of protection. My opinion.
Steve Young
Second Owner
SOLD
SOLD
Old 07-02-2020   #5
Several quality full synthetic oils out there - just have to be careful of the "ZDDP" (zinc/phosphorus) levels are in/close to the levels present when the LT5 was built (early 90s) (See Marc Haibeck's article/presentation on the virtues of Amsoil he recommends for the LT5.)
I buy Marc's Amsoil by the case. I seldom drive 3000 miles in a season, which means if I change every other year it comes down to the price of a tank of 93 octane. Nothing but the best for our 2 babies! (90/91 ZR-1s)
