Old 06-26-2020   #21
Perry Mitchell
Default Re: Extreme rich condition
I will try fresh gas tomorrow but I don't understand how stale gas makes for a rich condition. I will report what I find. Thank you
Perry Mitchell is offline   Reply With Quote
Old 06-27-2020   #22
Pics of gas, plugs after running just a few minutes, plug post flush
Old 06-27-2020   #23
Originally Posted by Perry Mitchell View Post
Thanks Paul. This information gives me something to watch and tomorrow I will time the pressure drop on the gauge. Is there a check valve somewhere in the system other than the fuel pressure regulator? Maybe at the pump? However, I don't see how a pressure drop, when the key is off, has any effect on the rich condition I have.
My bad - my unspoken thought was to verify the fuel pressure regulator was not going haywire: I shoulda said that up front (and the rest would have made more sense!).
Clarification needed here: Yes, there is a check valve - one each in both pumps. But, you're correct in that a leak-down test (which I was describing) would not have anything to do with ALL of the cylinders running rich: more an "FYI" for future use perhaps.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-27-2020   #24
Fast bleed off of fuel pressure at key off could show signs of leaking injectors
Old 06-27-2020   #25
Perry Mitchell
True, however I had the problem with the original injectors. I replaced them with new FIC injectors and the problem continued. I am at a loss.
Old 06-27-2020   #26
So I suggest, pulling plenum, pull injector rails, leaving everything on the rails. Put the rail over a cheap dollar store roasting pans, connect battery, turn key to on, look at injectors. See if any are dripping or leaking.
I bought rebuilt FIC injectors in 2008, I ended up having 2 leakers and no issues since. Still using same injectors.
This will confirm fuel not leaking.
I also think you need to get a scanner on the car while running and see what the data shows. If you don?t have a scanner maybe someone lives close, if you were near me I would be happy to help with my scanner
Old 06-27-2020   #27
Perry Mitchell
Good advice Jeff. I will probably end up doing just that Wish you were closer to me.
Old 06-27-2020   #28
If you have an Android device.. you can get ALDLDroid for $20 and then buy a Bluetooth or usb cable and use the android. Or use a windows computer with TunerPro, which is also free.. having these cars especially at 30 years old these tools are helpful
Old 06-27-2020   #29
This cable and tunerpro on a windows pc would work
http://www.reddevilriver.com/site/mo...aldl.html#2625
Old 06-28-2020   #30
DITTOS on a "scanner". Mine is "NLA", but it has paid for itself many times over in frustration alone! (Have wanted a "Notebook" and Tunerpro for some time. I have a birthday coming up...)
90 #1202
Sans secondaries
