#31 |
![]() Join Date: Jan 2006
Confirming the Summit Pulley does not need ANY spacer between the fan blade and the pulley. The Summit has the built in lip on it. Right now I have the housing the inside spacer which is correct size, then fan, then stock alternator with wrong size came with a WIDE spacer unlike the one it replaced..both had an L98 pulley on it, so I install the summit directly on top of the fan blade?
#32 |
My two spacers choices if needed between the blade and pulley are 10.2mm and 5.72mm. Do I need either between fan and pulley..side note, this new alternator came with a round circular disc protecting the fan blades (thin round disc- I am NOT going to use that)
#33 | |
#34 |
Here are pics
#35 |
So with the summit pulley, the outer spacer is not needed? The bearing mounts flush (the bearing has the offset) against the fan?
