Old 06-10-2020   #1
32valvZ
32valvZ's Avatar
Default Delphi Fuel Pumps
Are they any good? They say Made in China on the boxes...
Also, if the plastic Y is still good, can I reuse it? (The sender is from a 19k mile car) How often do they really fail?
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 06-11-2020   #2
Bradjon
Default Re: Delphi Fuel Pumps
On failing you just dont know they could last for 40 years or go tomorrow . If the ones in the car are working by the new pumps put them in the well in the back seat along with a screw driver 10 mm socket a couple of tye wraps and some 4 replacement worm clamps 1/4 in I believe and if they go out you can replace them in a 1/2 hour getting the unit out of the tank can be a little tricky just take your time .my car just went past 250 k and I just put in my second set but I always keep 2 back up pump in the car at all times . Hope this helps
Bradjon is offline   Reply With Quote
Old 06-11-2020   #3
dredgeguy
dredgeguy's Avatar
You can keep replacement pumps in the car or you can travel with the fuel pump jumper
http://www.zr1.net/forum/showthread....el+pump+jumper
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-11-2020   #4
Bradjon
Except this last time both went out together . Weird huh
Old 06-11-2020   #5
32valvZ
32valvZ's Avatar
Honestly, I was really wondering about the Delphi pumps as far as reliability since theyre not made in the US and are Made in China... Im not sure I would even have another choice with a ny brand pump.
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 06-12-2020   #6
dredgeguy
dredgeguy's Avatar
I use Electric Performance Fuel Pumps P-240KC from Rock Auto and they cost about $20/each. Just looked at the box and it does not say country of manufacture but does reference a USA patent.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 06-15-2020   #7
I?ve got a new OEM sending unit and I replaced the new Delphi fuel pumps with aftermarket fuel pumps.
Old 06-15-2020   #8
PhillipsLT5
PhillipsLT5's Avatar
ACDELCO TS1
ACDELCO TS3
ACDELCO G1
AIRTEX E3240
AIRTEX E3240
Old 06-15-2020   #9
32valvZ
32valvZ's Avatar
Thanks guys, I already installed the Delphi pumps... so far theyre good. Restart is good after sitting and throttle response seems a bit better with them in.
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 06-17-2020   #10
ZWILD1
ZWILD1's Avatar
I did the pump replacement on my previous car back in 2008. The sending unit was in great shape. Replaced the hoses and sock also. I really like Marc's solution using a standard single sending unit and one high flow pump covered in the last Heart of the Beast. Being that my run has the secondary delete when the time comes I'm going with one pump.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
