Old 04-22-2020   #21
MuRCieLaGo
Default Re: Car back from body shop - horn buttons don't work
So the plastic cam nub is broken off. It needs to make constant contact so push in an very small wedge a slither of wood or paper in the hole to retain it into position. It’s the ghetto method but it works, GC
So simple haha, I'll give the glue one more chance then I'll try that! Will post a picture if I fix it that way!
Old 04-22-2020   #22
Corvette95
Corvette95's Avatar
How about cutting a straw and slip it over the broken shaft and glue it OR taking heat shrink wrap insert the connector and shrink the wrap over the shaft?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 04-22-2020   #23
MuRCieLaGo
It would need to be a pretty big straw! And heat shrink wrap... I'm not sure it would be able to handle the constant spring pressure!
I just went for a 20 miles ride in town now, horn still works. To be continued.
Old 04-22-2020   #24
garyhugo
garyhugo's Avatar
You should be good for awhile. I used a tooth pick about 7 or so years ago and the horn still works. I've since then bought the plastic piece but don't want to tear the steering wheel down far enough to replace it until I need to.
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 04-22-2020   #25
Mystic ZR-1
Mystic ZR-1's Avatar
Now that you mention it, and reminded me, I fixed mine in the same way. Jammed a small piece of scrap plastic in the hole to hold it. Been working fine for several years now.
Old 04-22-2020   #26
Once again my point....the method is simple and it works. GC
Old 04-22-2020   #27
Yep it’s that easy
Old 07-03-2020   #28
Corvette95
Corvette95's Avatar
This thread was never updated!!! It also jinxed me. Putting the wheel back on the 90. I see that someone had crimped a new wire in it before. Dorman makes an exact fit replacement part # 49319
Old 07-04-2020   #29
MuRCieLaGo
Well, personally I've got lucky to still get the broken part. 3 layers of glue did the trick, I used the horn on the highway yesterday again and everything is good!
