Old 03-29-2020   #1
Ccmano
Ccmano's Avatar
Default LT5 Miscellaneous Parts
LT5 Parts
Great parts still available, feel free to make an offer. I am finalizing the parting out of a 1990 LT5 engine. Only these miscellaneous parts remain. The engine was in storage for the past few years that I am aware of. Not sure exactly how long. It reportedly had ~35k miles when removed. All the remaining parts I have available now are listed here. Im open to offers on everything especially multiple items. Prices listed do not include shipping. PM to make offers. Payment via PayPal only. The whole lot is available for a significant discount.
H
Injector Housing bolt set. $25
Throttle body bolt set $25
Fuel Pressure regulator vacuum line $15
MAP Sensor with plenum bracket $55
MDPS Sensor with the ECM bracket $55
Secondary throttle plate arms, washers, nuts set $79
Secondary linkages and mounting brackets with bolts $65
AC compressor, functional, no clutch $129
IAC Motor $25
Intake air temp sensor $25
[B]Both under plenum water temp sensors $35
Drive shaft with the yoke attached $149
Cam cover vent lines 1 driver side available $20 ea.
2 Flywheel bolt sets $39 ea
2 New Knock Modules (90 only) $99 ea.
Power steering bracket with bolts $39
Water pump pulley with screws $39
Right and left engine mount brackets with bolts $70
Vacuum line keeper with bolts, mounts to PS reservoir $35
1 set ground bolts to top of bellhousing $25
1 set Bell housing mounting bolts $39
1 set DIS Module mounting bolts $20
Oil filter housing $150
1 set oil filter housing mounting bolts $20
1 set starter mounting bolts $20
2 Alternator brackets $25 ea.
Engine Wiring Harness Loom $20
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-29-2020   #2
Ccmano
Ccmano's Avatar
Default Re: LT5 Miscellaneous Parts
Old 03-29-2020   #3
Ccmano
Ccmano's Avatar
Old 03-29-2020   #4
Ccmano
Ccmano's Avatar
Hold for pix
Old 03-30-2020   #5
spork2367
Do you have the two screws that hold the MAP bracket on to the plenum?
Old 03-30-2020   #6
G8nightman
G8nightman's Avatar
Can you do metal distribution pipe for 100 shipped?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 03-30-2020   #7
Ccmano
Ccmano's Avatar
Just want to be clear, your referring it the coolant pipe, correct?
H
Old 03-30-2020   #8
G8nightman
G8nightman's Avatar
Correct.
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 03-30-2020   #9
Ccmano
Ccmano's Avatar
Sorry, I don’t have those...
H
Old 03-31-2020   #10
Hans,
Any chance u have the mounting bracket for the throttle cable? I may be interested in the passenger side cam cover vent tube.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
