Old 03-21-2020   #1
Corvette95
Corvette95's Avatar
Default 90 Evaporator Housing/Heater Box R/I Tips ?
I pulled the evaporator housing on my 90 to remove the right side cam cover. The housing is off, I did it without disconnecting the evaporator and discharging the a/c . I searched for a "how to tip" but didn't find anything useful nor was the SM very good. Is there any good write ups on this or any tips to reinstall? The two 7mm screws on the engine side bottom of the box was a huge tasks. Should I go ahead and discharge the a/c and pull the lines? What is the best way to tackle this as there is no "easy" way. Thanks. ( I know I need to make sure the seal to cowl is tight on reinstall). Hope everyone is staying safe and healthy.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-22-2020   #2
Corvette95
Corvette95's Avatar
Default Re: 90 Evaporator Housing/Heater Box R/I Tips ?
anyone?
Old 03-24-2020   #3
Coupe89
No tips here. Those 2 bolts are a bitch. I didn't reinstall my bolts yet....
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 03-24-2020   #4
Jagdpanzer
Jagdpanzer's Avatar
I use a 1/4” drive ratchet and long extension to get at the 7mm head screws located on underside of the AC temperature control cover. Come in from the front side and use a mirror if you have to to line up wit the screw that goes in the firewall. Leave the Freon lines and evaporator alone. I’ve never had to remove anything further to get at the right hand cam cover or remove the engine
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
