Old 01-26-2008   #1
ZR1Vette
ZR1Vette's Avatar
Default 1990- Oil pressure guage>>
Just curious..where does the your (obviously the ZR-1) oil pressure guage sit when first start up? After warm up at idle? and at lets say 4K rpm? Mine seems to sit at about 3/4 up on the guage constant except at higher rpms a couple ticks below 80. New oil, filter etc so am just wondering if the gauage reading is the normal mode?
Michael
Old 01-26-2008   #2
lbszr
lbszr's Avatar
Default Re: 1990- Oil pressure guage>>
Haven't ran mine for about a month but seems hot it's about 40 at idle and 60 to 70 at anything above idle, mine was running just a hair under 80 all the time , it was the transmitter which I've heard is a common problem if it's the original one, if there's oil in the electrical connection like mine had it's bad for sure, could screw a mechanical indicator in if your not sure if it's accurate incase there's nothing wrong.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 01-26-2008   #3
ZR1Vette
ZR1Vette's Avatar
I began reading about the some what common pressure sender issue...where is the oil pressure sensor sending unit located?
Michael
Old 01-26-2008   #4
lbszr
lbszr's Avatar
It's just inboard of the right water outlet pipe on the oil filter adapter sitting vertical, plug is easy to pull off and look for oil, one of the easiest things to get to.
Old 01-26-2008   #5
ZR1Vette
ZR1Vette's Avatar
Got it! Good info and big thanks
Michael
Old 01-26-2008   #6
bradslt5
i had an interesting thing happen recently. changed the oil and filter and the pressure wnt down on the gauge alot . to half way when hot . scared me a bunch . got another filter screwed it on and poof things were back to normal. anyone had this happen to them also?
