Old 03-10-2020   #1
Zman
Default Fan won’t shut off
Took my 1991 out last weekend on a bumpy road. When I got back and parked the car my fan kept running after the car was shut off. Left it thinking it will cool and shut off. Today it had a dead battery. I jump started the car and drove it for about 15 minutes. The fan turned on immediately when the cables were hooked up and continued to run after the short drive. When I went to disconnect the battery I noticed the negative battery terminal was loose. I will try recharging the battery and tightening the battery cables. Anyone ever had an issue like this? The fan that runs seems to be the blower fan for heating and cooling.
Zman is offline   Reply With Quote
Old 03-11-2020   #2
9T1 Red ZR1
9T1 Red ZR1's Avatar
Default Re: Fans doesn’t shut off
Hello,
Here is a link that may help.
Good Luck,
Bill
http://www.zr1.net/forum/showthread....ghlight=blower
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 03-11-2020   #3
Mystic ZR-1
Mystic ZR-1's Avatar
Efnfast, this sounds like the problem you had?
How did ya resolve it?
Old 03-11-2020   #4
Originally Posted by 9T1 Red ZR1 View Post
Hello,
Good Luck,
Bill
Thanks for the link
Your Post above now in -Solutions- .......
See -Solutions- Post 7 - ZR1 Specifications, Restorations, Air, Bose Audio, Lifts (AIR CONDITIONER & HEATER).
