Old 02-23-2020   #1
RICKYRJ1
RICKYRJ1's Avatar
Default Corsa X-Pipe
Does anybody run an X-Pipe on their Corsa exhaust? I seem to only see B&B with them. Is there no upside? or is there possibly a downside? Is removing the existing resonator and replace with straight pipes produce any gains? Thanks in advance for any and all advise. Rick
Old 02-23-2020   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Corsa X-Pipe
Hi Ricky!
I replaced the Borla resonator on my Borla exhaust system
with a B&B X pipe. I dynoed before and after and gained 25 rwhp.
I like the sound better, not much louder, but yes, drones at about 1800 rpm.
Old 02-24-2020   #3
The beauty of the Corsa system is by design. The inherenty designed (Helmholtz) resonator section cancels certain resonant (sound) frequencies and mitigates others as well - without impeding the flow of the exhaust gasses. IOW, the Corsa IS essentially the same as removing the stock resonator and installing straight pipe in its place. So, there wouldn't be any practical (if any) increase in performance by swapping straight pipes for the Corsa resonator section.
As for the X pipe, specific HP improvements in performance depends on what else comprises the exhaust system, e.g., w/ or w/o headers, mufflers used, etc. But, specific quantities aside, the improvements experienced by many before and after users is "all good": up to 25 rwhp is commonly claimed. (YMMV). I have one (from Stainless Works). My fully ported (except for throttle body) motor with LT (SW) headers, 3" exhausts and somewhat restrictive mufflers makes 432 rwhp (before last improvements). How much is due to the X-pipe? I dunno. But, it's part of the package, and I "think" it helps...so it does!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-24-2020   #4
32valvZ
32valvZ's Avatar
Which mufflers you using Paul?
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 02-24-2020   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Paul,
B & B has the Helmholtz chambers in the mufflers.
Wouldn't having them in either place address the resonance?
Does Corsa have them in both the mufflers and the resonator?
If one does the job why have more?
25 added HP from the x pipe is astounding!
That rivals many an internal mod.
I guess I will finally install my other B&B Fusion system with the x-pipe that have been sitting on the boxes since 2014.
Marty
Old 02-24-2020   #6
32valvZ
32valvZ's Avatar
I noticed a definite seat of the pants improvement going from the regular exhaust configuration and sizes, to all 3" with X pipe and mufflers (all SW). Sounds great too... Yes on drone... I dont mind it though.
https://www.lmperformance.com/662816...th-x-pipe.html
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 02-24-2020   #7
Originally Posted by DRM500RUBYZR-1 View Post
Paul,
Marty
Marty,
My understanding is that resonators and mufflers address different frequency range. Resonators are low frequency and higher frequency handled by the mufflers. At least, above is my understanding.
Introducing X pipe, I think, complicates the issue.
Any acoustic engineer out there?
Old 02-24-2020   #8
RICKYRJ1
RICKYRJ1's Avatar
I dont mind adding more noise for more HP. Car currently has a Haibeck 500 hp pkg. Corsa exhaust no cats. She runs great as is but always looking for more.
Old 02-25-2020   #9
Hi Ricky!
Drone is not exactly extra loud noise. It's similar to standing in front of a large subwoofer. It's a low frequency vibration that goes through your body. I was getting nauseated by this when I experienced it.
Old 02-25-2020   #10
Paul,
Marty
Yes, the Corsa has them (Helmhotz) in BOTH the resonator section AND the mufflers - both designed to work in tandem in order to cover the widest range of resonant frequencies.
90 #1202
Sans secondaries
