Old 02-15-2020   #1
Stingray1967
Default Cold starting ZR-1 question
Ok guys, yes there is still snow on the ground in MN, but I'm already thinking spring.
I'm wondering, when I go to start my old 'vette, I DON'T give it any gas and I hit the key a few times for a few seconds each. That has the effect on my carbureted car of spinning the motor with no ignition, and letting the oil pressure come up before starting.
Can I do something similar on the ZR-1?
Chris
Stingray1967 is offline   Reply With Quote
Old 02-15-2020   #2
Ccmano
Default Re: Cold starting ZR-1 question
Yes you can. Floor the gas pedal and keep it there while turning the engine over. This feature was designed to clear a flooded engine but works equally well to turn the engine over without starting it. I also use it when running compression testing.
H
Old 02-16-2020   #3
Stingray1967
Thanks! I'm assuming that works on all years of ZR-1s? I have a '94.
Old 02-16-2020   #4
Ccmano
Yes all years...
H
Old 02-16-2020   #5
Stingray1967
Thanks!!
Old 02-16-2020   #6
Mystic ZR-1
Mystic ZR-1's Avatar
Sounds like it would be a good way to do a cold start after Winter storage?
Old 02-16-2020   #7
BigJohn
BigJohn's Avatar
If y’all do it on the jack stands; can I Watch???
Old 02-17-2020   #8
Stingray1967
Exactly what I was thinking. All of the oil has drained down off the motor in the last 5 months. Startup is always the hardest "wear point" for an engine. Not enough oil pressure immediately on startup, and a relatively high demand.
Old 02-17-2020   #9
Stingray1967
No jack stands here.
Old 02-17-2020   #10
Mystic ZR-1
Some like to start their stored cars every week or so.
I’m a fan of only 1 cold/hard start at the end of storage.
Why subject the motor to several of them.
The WOT method at initial turnover makes this even better.
The jackstands? That’s debatable...
