#21 | |
![]() ![]() Join Date: Nov 2007
[QUOTE=32valvZ;302776]
I don't have a Dyno graph of my motor with only top end* porting. I wish I did**. Instead, I have to derive an estimate of rwhp by subtracting the known gain achieved by others after the heads too were ported (that being between 25-35 rwhp) to approximate what my top end only porting was. The Dyno graphs show the before (stock) peak starting point, and peak after that establishes the full porting (and cam phasing) improvement - the bulk of improvements up to that time: starting at 336 avg rwhp and ending with 432 rwhp with HEAD porting included. So, est. of "400" rwhp before porting the heads is reasonably accurate, in my estimation. Dyno graphs and HP numbers and estimates are popular for most - salesmen especially. But, where rubber meets the road means more to me than HP bragging rights, and actual force at the wheels, i.e., TORQUE over the entire rpm range, or POWER UNDER THE CURVE gives a better indication of the worth of any modifications - to me, anyway. *TOP END included the plenum and IH brought out to 36mm, and later 37.5mm
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
#22 | |
![]() Join Date: Aug 2015
From a fluid mechanics perspective, sharp upsets, especially when fluid flow direction is such that a sharp reduction in diameter is encountered, causes significant turbulence and reduces laminar flow velocity (volume reduction). So, having a beautifully ported plenum and injector housing will deliver reduced volume by presenting the fluid stream with a sharp restriction like the stock primary runner on the head. Gasses can be compressed, so a smooth reduction in crossection, especially when extended over a reasonable distance, allows most of the fluid volume (air) to "get through". The fluid is moving at a higher velocity.. I've not done a top end port without port matching the heads, so I can't provide actual hp/tq numbers or cfm data. I do know that my experience before and after top end port with port matched primaries, headers and tune yields a consistent 50 rwhp on our Mustang Dyno. Headers and tune deliver about 20 rwhp, port another 30 rwhp. This is with stock DM Flywheel as well as stock diff ratio. Using 15% loss, that would be 24 crank hp for headers and tune and another 35 crank hp for top end port and tune. Total engine hp gain 59 hp.20191114_060111.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#23 |
If I remember correctly,LGAFF, one of the long time members had several ZR-1s and did porting with and without port matching to the heads. He found the difference to be negligible. +-~5hp or something like that. Let’s see if he chimes in on the one.
H ![]()
[B]90'ZR-1[/B] #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold [B]08 C6 Z51[/B] Crystal Red Metallic Sold Vararam Intake, Tune, Sold [B]05 C6 Z51[/B] Red/Black Sold [B]90'ZR-1[/B] #1723 Black/Gray Sold but not forgotten [B]91' Z51 L98[/B] White Vert. My First, you always remember your first. Sold. |
#24 |
Well, Im sure there are a few ponies left on the table by not port matching the heads... It does make sense that necking down a passageway will interrupt flow of fluid or air... similar to exhaust.... BUT, Im pretty happy with the results of only the plenum and IH's. Give me some time... Ill catch up!!
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
#25 | |
[/ATTACH]
This is a conceptual picture of a carbide porting tool I sent to a tool and die maker (10 years ago) that would facilitate the rapid porting matching of the head with respect to something closer to ideal laminar flow. The idea was to not only expedite the porting process, but to also mitigate the chance of breaching into either the coolant or oil areas. (But, since I had already completely ported my heads by that time, the couple hundred bucks for a tool no longer needed (by me) ended my pursuit of the bit. And, too, there was the question of being able to secure/position and power the bit if the head was not first removed from the motor - a step unnecessary if only doing a "top-end" port job.)
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 02-11-2020 at 12:02 PM. |
#26 |
And, another diagram derived via trial and (expensive!) errors!
#27 |
AND....
One more, as long as we're on the subject of porting (yes?), supporting the LONG TAPER theory, one of the examples is this set of Webber VELOCITY STACKS mounted on single throat carbs. Check it out. ![]()
