12-20-2019 | #1 |
First start of w new short vlock and intake cam.
Dr. Greekenstein gets motor with new short block, a new intake cam and lifters started w just a few cranks. You’ll hear him use an expletive to describe a vacuum leak at the plenum which he remedies just a few hours later.
https://youtu.be/jEld_-B3bVo
12-20-2019 | #2 |
Re: First start of w new short vlock and intake cam.
Nice! Starting a fresh build is always nerve wracking especially with the noises it initially makes. Can’t wait to see the Dyno sheets after it’s tuned.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
12-20-2019 | #3 |
Hans,
As we know its pretty routine for someone like Pete. And the tune was good on it anyway. Just making sure the new lifters and cam meshed well. A bit noisy at startup, but once lifters pumped up, it smoothed and quieted down noticeably. Oil pressure VG and coolant temps fine. No leaks. Now getting exhaust welded up by Al to eliminate slip on joint and exhaust leak ahead of Xpipe, which was the main issue after all is said and done.
12-21-2019 | #4 |
Nice !!! I’m looking forward to the day I can begin a build with Pete !! Hopefully soon !! Any more details on the build ?
12-21-2019 | #5 |
Nice!
I would like to upgrade my cams and get an extra 20 to 25hp and more useable rpm out of the motor. The money to power gains seems pretty pricey.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
12-21-2019 | #6 |
The motor has been upgraded incrementally. So I started w a ported top end + exhaust. That produced 397rwhp.
Then Pete and I put on ported heads, and intake cams. That reached 430rwhp. Very nice motor for street. Good idle quality w good performance. I didn’t necessarily want to go w exhaust cams at first. But Pete persuaded me to go ahead. So finally, we added exhaust cams which brought power levels to 454rwhp. Tuning helps tame idle. Power is intoxicating. Would not go back. These numbers are all SAE. Uncorrected, the motor w exhaust cams produced 464rwhp/411rwtq.
