Old 10-07-2019   #481
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Pic #9...these plastic fasteners are also used in the bottom spoiler area....one on the LS is the exact replacement....RS is the stock part...
Pic #10...the Hillman Ford parts are the same as what is on the ZR-1....
Pic #11....2 to a pack....20191007_164047.jpg20191007_164128.jpeg20191007_164147.jpeg
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-07-2019   #482
Roadster
Roadster's Avatar
Pic #12....also purchased some extra bolts attaching the lower radiator support in place...as they are a different style of bolt....the 94 is on the far right....the other 4 are "just in case"....
Pic #13.....topside....in very good shape....all cleaned and ready to go....20191007_162521.jpg20191007_162525.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-08-2019   #483
HAWAIIZR-1's Avatar
Default TB removal and then some!!!
Hey Tom, Just a note to say thanks for sharing. You probably have no idea how much your posts will help someone one day. Some good details and lessons learned and good how to. Even the “lurkers” appreciate it I’m sure. When people are appreciated I know it motivates them to continue the act. Take care and keep up the good work.
Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 10-08-2019   #484
dredgeguy
dredgeguy's Avatar
Tom,
Wazoo maintenance day this Saturday. Hope you can make it.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 10-08-2019   #485
Roadster
Roadster's Avatar
Originally Posted by dredgeguy View Post
Tom,
Hello Charlie, wish I could make it. But have too much going on, plus threw my hip out. The 94 is all apart and working to get the 74 back together within this month or next month. Say hello to everyone and have a fun day!!! Here is the current status of the 94 as you may have seen some pics, did some bracket painting for the 74, still more to go, making a new fuel line and getting the carbs squared away. Getting there, keeping me busy......chat soon [emoji16][emoji16]20190907_153020.jpg20191008_120440.jpg20190501_130737.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-08-2019   #486
Roadster
Roadster's Avatar
Aloha,
Thanks Craig, it is appreciated and I do hope they help in some way or another in addition to the technical work that Cliff has compiled over the years. These are just added little tidbits I figure I would post up and hopefully help others if they intend to do this type of work on their ZR-1.
Looks like everything is well on your end, some great pics that you have posted from your new location. Take care yourself....chat soon!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-08-2019   #487
S.hafsmo
S.hafsmo's Avatar
What he said. I don't post much, but always read.
- '90 ZR-1
Old 10-09-2019   #488
Roadster
Roadster's Avatar
Thanks and appreciated.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-09-2019   #489
HAWAIIZR-1's Avatar
Hey Tom! You’re very welcome. It is understood the time and effort it takes to do write ups and take photos. Yes, you’re right about Dynomite Cliff and I’ve shared the same with him over the years. As you know a few years of hiatus from the Z, but never forgotten are the friends on here. Take care and Aloha!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-14-2019   #490
Roadster
Roadster's Avatar
Having researched through the forum on AC condensers....I ended up purchasing a Spectra Premium 7-4557 condenser for my 94 ZR-1
There was mention in the older threads that this unit may not have provisions to install the oil cooler, this unit does with one exception and that is you need to elongate the holes on the RS (passenger side) of the oil cooler for it to fit and possibly use a larger washer under the 7mm attaching screw....no biggie...
As you may be able to determine in the pics, the body of the new condenser is slightly smaller than the original unit.....even the overall dimensions from side to side are slightly less....but the top to bottom measurements and the hose connections measurements are the same....the only difference in modifications that I can determine at this point is that the RS upper and lower front part of the radiator rubber cushions would have to be slightly modified to make sure that the new condenser is secured...
Having said that I am taking my original condenser to get pressure tested and make my decision when I get back the results....we shall see...
Here are some pics....
Pic #1....numbers on the original condenser...
Pic #2...the original...
Pic #3...original with oil cooler...
Pic #4...Spectra part #...
1974 LS4 454 Vert
1974 L-82 355 Vert.
