Old 09-24-2019   #11
Hib Halverson
Default Re: MEMCAL card
Unbolt the FPR and its bracket and move it out of the way.
Feel for the 1/4 hex head bolt which holds the connector to the DIS module. Unscrew that bolt then unplug the harness.
You'll need a aerosol can of contact cleaner which has one of those plastic straws. Spray into the connector on the end of the harness. Then spray into the connector on the back of the DIS module.
Reconnect the harness and tighten the bolt.
Then, road test.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 09-25-2019   #12
Jax ZR1
Still getting a code 42 after cleaning the connection , I
Jax ZR1 is offline   Reply With Quote
Old 09-26-2019   #13
Hib Halverson
Well...go back and read what I said in post #7.
Hib Halverson
Technical Writer
Old 09-26-2019   #14
Jax ZR1
I replaced the battery today and and have went for a drive and it now seem to be ok. Going to keep an eye on it and hope it is ok .
Old 09-27-2019   #15
Hib Halverson
You know...
(sigh)
...I forgot to tell you to clear codes after you cleaned and reconnected the DIS connector. Sorry 'bout that.
When you changed the battery, you cleared codes when you disconnected it.
Hopefully, the 42 will not come back and you can chalk it up to loose/dirty connections.
Hib Halverson
Technical Writer
Old 09-28-2019   #16
Jax ZR1
Originally Posted by Hib Halverson View Post
You know...
(sigh)
Thanks for the help, made it as far as Seattle yesterday, hopefully the car keeps running good and the rain can stay away. Looking forward to driving down the coast highway.
