Old 09-13-2019   #1
Jetjock
Jetjock's Avatar
Default Door Hatchback Release Switch
On my 93, the door hatchback release is not working. It was intermittent but now it doesn’t work. The release button in the console works as well as the fob. I’m going to pull the door panel off and check it out but is there anywhere I can get another switch?
Roy
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 09-13-2019   #2
bddeuce
Default Re: Door Hatchback Release Switch
It may just have some corrosion on the contacts? Mirrock corvette typically has them.
bddeuce is offline   Reply With Quote
Old 09-13-2019   #3
do your dome/courtesy lights work with that door open? I think they tie into that switch too, but I forget.
Old 09-13-2019   #4
Jetjock
Jetjock's Avatar
I had a weird thing happen today. The interior lights did not come on. They were good because I could turn them on with the dimmer switch. The door jamb switch did work. Then after a drive, everything started to work again. Weird. Including the door hatchback release.
Roy L. Carman
NCM Lifetime #1468
Old 09-13-2019   #5
ghlkal
ghlkal's Avatar
Yup, if the door ajar/open switch doesn't work, the hatch release won't work either.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 09-13-2019   #6
Originally Posted by Jetjock View Post
I had a weird thing happen today. The interior lights did not come on. Then after a drive, everything started to work again. Weird. Including the door hatchback release.
After a drive you charged up the battery
Old 09-14-2019   #7
Jetjock
Jetjock's Avatar
I have the battery on a tender so the battery is always charged. It does this wether I drive it or not, so I suspect contacts are the issue. I’m replacing the weatherstrip on the door panels so I will check it when the panel is off.
Roy L. Carman
NCM Lifetime #1468
Old 09-14-2019   #8
Either contacts of the door switch for the courtesy lights or that switch is sticking
Old 09-14-2019   #9
Jetjock
Jetjock's Avatar
I’m taking the door apart next week to check it out.
Roy L. Carman
NCM Lifetime #1468
