#11 |
![]() Join Date: Jun 2015
On my car which I believe has stock pulleys, an 80" Dayco would not fit. I went and got an 80.5 inch it went on in 15 mins and my tensioner rides in the middle of its range.
#12 |
![]() Join Date: Nov 2007
I stretched the take-off belt and the new belt, looped between my index fingers. Perhaps not particularly accurate - at least not to a 1/2" tolerance. But, the new belt does fit. However, I'll go see how the tensioner is positioned. (That aspect never crossed my mind until you brought it up. Hmmmm....)
#13 | |
That be your belt length. Then if you get a smooth Aluminum Water Pump Pulley (Pete can get them), it becomes super easy to replace the serpentine belt slipping the belt onto the Aluminum Water Pump Pulley that has no larger diameter like the Stock Water Pump Pulley........or like trying to slip the belt on any of the other pulleys that all ride on the ribbed inside of the belt. ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-13-2019 at 11:54 PM. |
#14 | |
Revisiting a somewhat older topic. I worked with a mechanic friend at the house the other day to install a new serpentine belt. It was relatively easy it seemed to me and I'm not much of a mechanic. The biggest issue that we ran into was the throttle body. There was not enough space between the throttle body and the top gear to get the old belt out or the new one in. So we lossened some of the torx screws holding the throttle body and were able to create enough space to get the belts through the opening. Hardest part was feeding the belts through the bottom area of the engine but that was overcome via a kind of tug-o-war effort over about 5 minutes. Whole job took about 20 minutes start to finish. |
