09-03-2019 | #11 |
Re: Sharp clicking from passenger rear half shaft area.
Hello all,
The root cause was found to be a loose axle nut on the passenger side. Bought a new nut and re torqued +10% and the issue is now gone. Thanks to everyone for all of the help. It’s greatly appreciated. |
09-03-2019 | #12 | |
And, Cliff, Marc's tip sounds like a good one for the SOLUTIONS collection, no?
09-03-2019 | #13 | |
Always keep me posted See.......ZR-1 Drive Train (Drive Shafts). Sharp Clicking Rear Axle Marc has over 40 Posts on this Forum many of which are -Solutions- That is not counting Solutions he has text me
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-03-2019 at 06:38 PM. |
09-05-2019 | #14 |
Just so everyone knows, The noise that was heard was the EXACT same noise you hear when you crack a lug nut loose. That really sharp creak sound happened each and every time I changed from forward to reverse.
Not to sure whether it was the splines moving in the hub, or the friction slip on the back seating area of the big nut, but after being tightened, the noise disappeared 100%. |
09-14-2019 | #15 | |
I'm kind of a geek and do consult the FSM prior to project while I watch college football and read the manual. (Roll Tide and Geaux Tigers!) For the life of me I CAN'T find the section of the FSM that covers this procedure? Section 4B is about the rear axle, but no mention of the axle nut?
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
09-14-2019 | #16 | |
You can do exactly as Marc suggests or go a bit further........Left Click on the Link Below. (Both involve tightening the Axle Nut)
Clicking from rear under initial load
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-15-2019 at 01:22 AM. |
09-14-2019 | #17 |
Thanks Dynomite- this is exactly what I need to do.
I must have missed it.... what size socket do I need for the nut? Looks like I'll remove the nut, repack with axle grease and torque to 190. Thanks!
09-14-2019 | #18 |
36mm Axle Nut.....If you want to go a bit further......
Post 240 - New Rear Wheel Bearings and Half Shaft U-Joints All tested recently on a 4,000 mile road trip
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-15-2019 at 01:23 AM. |
09-14-2019 | #19 |
Thanks! You rock!
09-15-2019 | #20 |
I did the "repair" today, removing the nuts "trying" to put a bit of grease in the spindle (I used a hypodermic syringe) but the tolerances would have nothing with it.
I used the torque wrench to get the nut to 190lb. I took it for a ride and did not hear the sharp "snap" as in the past. I did hear a very, very soft *pop* occasionally as I transitioned from forward to back. I admit I was "looking" for a sound so I could have imagined normal car noises. If the radio was on at any volume I probably would not notice anything-- again I was listening hard. So, would you leave things alone for go back in and put an additional 10lbs on the nut?
