Old 08-07-2019   #1
ZuggZR1
ZuggZR1's Avatar
Default Driveway Bottom out
Anyone have the issue where your car bottoms out at even the slowest speed on your driveway. If so what did you do to resolve this ? As you can see from my pics the driveway has a small runoff all the way around my culd-da-sac
ZuggZR1 is offline   Reply With Quote
Old 08-07-2019   #2
Ccmano
Ccmano's Avatar
Default Re: Driveway Bottom out
Are we talking the spoiler scraping (normal) or something else?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-07-2019   #3
That is spoiler issue.
A little concrete and couple pipes (steel or PVC)
Old 08-08-2019   #4
billschroeder5842
billschroeder5842's Avatar
An easy, temporary solution would be a 2x8 piece of wood placed over the low spot. It will work well, but is will be a PITA.
If it is your spoiler, I'd just cringe and deal. I put a new spoiler on my 91 about 3 weeks ago. It tool me about 60 minutes.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 08-08-2019   #5
Karl
Karl's Avatar
I assume you are not driving into the driveway nose first. If so then you need to approach at almost a parallel angle and come into the driveway. If there is a car on the street next to the entrance that could be an issue.
1985 L98 Blue On Blue *Sold*
Old 08-08-2019   #6
RussMcB
Here's what I did to help loading my low race car into the trailer on a regular basis. Maybe you can do something similar.
Slowly go into (or out of) the driveway and right before the spoiler starts to touch, mark that as the beginning of where you need to start raising the nose of the car. You'll want some kind of "bump up" under the tires from that point until you get past the problem.
Sorry, I don't have any great ideas about what material the "bump ups" might be. For my trailer ramp door I just fastened 2"x8"s.
If it isn't often, use boards with handles and just know where they need to be placed.
But, we're pretty fortunate that our front air dams are pretty tough and cheap, and don't show scrapes much.
Old 08-08-2019   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Works every time!
Just remove before snow plows come along if applicable.
https://www.amazon.com/Car-Driveway-...540902285&th=1
Marty
Old 08-08-2019   #8
dredgeguy
dredgeguy's Avatar
That is a great find Marty! I ended up hiring a contractor (our lawn guys) to bust up the last 10 feet of my driveway, regrade it and pour new concrete. Problem solved but yours is a better deal!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-08-2019   #9
Originally Posted by DRM500RUBYZR-1 View Post
Works every time!
Marty
That might work nicely, IF the city won't frown on setting anchor bolts in their curb n gutter work. But, what they don't know...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-08-2019   #10
32valvZ
32valvZ's Avatar
An easy and relatively inexpensive way to resolve this is with a piece of steel. Just get a piece from a steel yard that fits across the "mote" and as long as you need it to be. In each corner have a hole drilled. Then get a contractor to fasten it in the ground using a Hilti or the like. Semi permanent and the water can flow under it like a bridge. Lots of people do that in these parts..
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
