Old 07-22-2019   #1
EvanZR1
EvanZR1's Avatar
Default Shelby wheels brake upgrade
Need definitive answers from folks on what the options are for front brake upgrades with Shelby wheels. The two options I'm aware of are:
  • C5 brakes: Will have to move center of wheel to outside and use spacer. Inexpensive option for brakes (I actually already have full C5 setup except caliper mounts), but if I'm going to have the wheels taken apart, I'm going to get them refinished at the same time. For those that have done this, does anyone have pics? Very interested to see how the wheels fit in relation to fenders. Also, what size spacers are needed? Alternately, has anyone thought of grinding down the calipers to clear (not sure if it's even an option based on how much would need to be removed)?
  • Wilwood Superlite kit: I've heard that this will fit, but I also saw someone on Facebook say they had clearance issues with Shelby wheels. It appears there are two different versions of this kit: a 12.88" rotor setup and a 14" rotor setup. Can someone confirm if either of these will clear the Shelby wheels "as is" (center face mounted inward (behind bolt lip))?
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
Old 07-22-2019   #2
Default Re: Shelby wheels brake upgrade
C5:
I assume you mean you have the Calipers and their associated brackets but are not using C4 to C5 adapters (I have seen this before)
That said, you will need to move the Centers out on the fronts to clear, you will also need a 3/16 minimum spacer.. I had C5 brakes with Shelbys
Wilwood Superlites (are these the Narrow Superlites)? I know the 12.88" narrow kit will work with centers in either spot. I have the NSL Wilwoods on my car (12.88") and originally had the centers on the inside, but moved to the outside to get the new tires I have to tuck better under the fender..
I also know the Standard SuperLites will need a spacer and be on the outside to keep the tire in more
With your C5 rears, I am guessing they should fit but I currently run the OEM C4 rears. If I ever buy that C5 conversion set-up for a drum parking brake, I will run C5 calipers in the rear
hope that helps and makes sense
Old 07-22-2019   #3
EvanZR1
EvanZR1's Avatar
Correct, I have the C5 front setup sitting on a shelf, but have not ordered the custom mounting brackets for bolting them to a C4. I wasn't planning on doing anything with the rears at present.
Here are the two options listed by Wilwood on their site:
https://www.wilwood.com/BrakeKits/Br...axle=Front+Kit
Both say "Narrrow Superlite".
To be clear, I'm just looking at upgrading the fronts at present.
Evan
2024 Z06
Old 07-22-2019   #4
The 12.88 will work, that is what I have currently.. Centers can be on the inside out outside of the barrel
Old 07-22-2019   #5
G8nightman
G8nightman's Avatar
I do not think the C5 brakes are worth the trouble.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 07-22-2019   #6
agreed.. If anything do the Wilwoods or leave it alone
Old 07-22-2019   #7
EvanZR1
EvanZR1's Avatar
Thanks, that's the kind of feedback I was looking for. I got them for a steal, so I should be able to sell them easily for at least what I have in them.
Evan
2024 Z06
Old 07-22-2019   #8
Sell? What time up going to replace them with?
Old 07-22-2019   #9
EvanZR1
EvanZR1's Avatar
Anyway, I'll sell of the C5 setup I never installed, and just buy the Wilwood 12.88" setup for the front.
Evan
2024 Z06
Old 07-22-2019   #10
Sorry,
What are you going to replace the Shelby’s with?
Oh you mean sell the brakes
